I've been mostly using repetier and the default settings that came from SeeMeCNC but was told that MatterControl(MC) did a better job of slicing and well control
All these tests are running ABS 1.75mm temp is ~220 bed is ~80
Sadly after a normal Repetier calibration (with the 4 scripts like in the manual) I printed this nintastic case from thingiverse.
As you can see from the group of pictures:
https://www.dropbox.com/sc/w3mizagj6ujh ... iK9zveSDFa
the red plastic with repetier turned out pretty good but i wanted to refine the prints and make the layers cleaner and with more detail (no idea how to improve this)
The grey plastic seems to be of poor quality as the same corner caves in all the time and i have not found a way to improve this.
Finally the feathered print that just looks awful is the MC one with the standard ABS settings from the site. As you can see it just failed in a big way. Somebody suggested that it was under-extruded.
I could definitely use some help and suggestions for the following:
1. How to improve the print quality of ABS with just repetier, get it to be smoother, more details, and not cave in (in the case of the grey filament). I have tried skirt/brim and increasing temperature.
2. What's up with mattercontrol slicing/printing this improperly ? There seem to be a plethora of settings other then the basic ABS ones so I'm all ears on how to methodically improve this softwares ability to print.
Any help is appreciated. This case is going to a friend for Christmas so it's more then just wanting to improve technique
