thermistor bad?
tom10122
thermistor bad?
Post by tom10122 »
I checked the continuity and nothing, my understanding is that it should atleast have some continuity, did i wire it wrong or something? I turned it on for like 30 secs to see if it turns off and it didnt
michaellatif
Re: thermistor bad?
Post by michaellatif »
The thermistor provided with the kit should read about 1.3MOhm at room temperature.
The datesheet is located at http://www.specsensors.com/pdfs/ntc_radial_glass.pdf SS&C Type G_1396
If you see it read nothing then you need to probably replace it.
One thing to keep in mind is the thermistor has a glass cover and can be broken.
Mike Latif
H-1 #3
tom10122
Re: thermistor bad?
Post by tom10122 »
well it seems to work fingers crossed, it does cycle on and off
johnoly99
Re: thermistor bad?
Post by johnoly99 »
Most meters wont see the resistance at room temos, but carefully measuring temps while it heats up, i work the pot on the velleman and bring it up to the lowest temo and make sure it cycles, then creep it up little by little to 425f and note the dial position.
