Delta geometry off, tilting effector plate
Posted: Tue Dec 23, 2014 11:58 am
Hey everybody
In order to get my Kraken extruder working properly, I am currently facing a problem with my printer geometry. After some email exchange with Michael, I think it's time to open up the discussion.
I observe the end effector plate of the printer slightly tilting when I move it along the X axis. Close to the X pillar, the left nozzle gets lifted off the plate by about 0.3mm compared to the right nozzle which gets pressed against the plate. The opposite effect happens at the Y pillar, but it seems not to be as severe as on the X side. At this moment, I am only using these two nozzles, so I cannot comment for any tilting in the Y axis.
Michael and I discussed geometry and angle adjustments and I tried to follow these instructions:
https://www.youtube.com/watch?v=qrrO0elGXJM
https://www.youtube.com/watch?v=E-92PSNINO0
Ironically, they both successfully use my bed levelling aid which I honestly was never able to successfully print (it always gets dragged off the plate, especially the small measuring points which slic3r prints separately).
I still don't get how people are able to precisely measure distances and angle deviations mid-air on this round design without expensive professional measuring equipment. However, I did correct some slight deviations in perpendicularity of the pillars to the printing plate. The angles of the three pillars seem to be right (measured to about 0.5° accuracy), but I could probably still tweak these, as I get some high and low points in positions on the opposite side of the pillars.
All that tried, the main issue still exists and thought over twice can actually only happen if
a) some rods don’t have the same length
b) some rod axles are not exactly mounted in parallel toward each other
According to my measuring and mostly trial and error, I think with about 90% certainty, that the cause of this problem is the Z rods tilting the plate. If I twist the Z pillar or the Z carriage with some force, the tilting gets resolved.
But I still don’t know the root of this problem. The rods seem to have the same length, the axles seem to sit flush in the shafts, and even the distance of the two carriage plates is the same on both sides of the pillar. Also the clearances of the pillar to the different wooden parts at the bottom of the pillar look very even. If somebody has a creative idea how I can measure the position of the axles against to the rest of the geometry, I would be very grateful. So far, I measured the Z position of the carriage axle ends to the printer plate and they both seem to be at the same height.
Have other people been confronted with such issues? What have they done to resolve them? Is there some old mechanics trick to measure such things as axle orientation to circular geometries?
