Does anyone have Autodesk Inventor? Can you convert a file f
Posted: Wed Dec 24, 2014 12:34 pm
by DarrenAnton
long story short...
I had to take my Rostock back apart to fix the cc chepskat plate's, (I put two on the wrong way) was working off the old 1.67 pdf file anyway the belt clamps got broke, cheap maylay wood stuff, I glued them back but I want to print more out in case they break or next time I have to take it apart.
I was only able to find this part in the RostockMaxv2_Inv2015 zip file, Part "0031.ipt"
I did download the Free Autodesk Inventor Viewer but can only view it
Can someone convert to a STL file for me or do you know if there is a STL file out there already, can not seem to find one
Looks like I can not attach a file here so here is a link
https://dl.dropboxusercontent.com/u/48324573/0031.ipt
Thanks
Re: Does anyone have Autodesk Inventor? Can you convert a fi
Posted: Wed Dec 24, 2014 1:46 pm
by RegB
I have inventor fusion, will try your file as soon as I can.
Do you have an e-mail address that I can send an stl file to if/when I make one ?
Probably best NOT to publish that, send me a board PM.
Posted: Wed Dec 24, 2014 2:15 pm
by bvandiepenbos
I don't think a .stl file exists for the laser cut belt clamp so I just created one from the .dxf laser cutting file.
Made it .270" (6.86 mm) thick as the melamine wood ones are.
part size is 60 x 12.7 x 6.86 mm
I literally just created it, so it has not been printed yet.
Ran it through netfabb and it looks fine.
I will put it up on repables.com also
edit: added .stl with size offset .19mm per side to simulate the laser cutting kerf. I think this may fit better when 3D printed.
Posted: Wed Dec 24, 2014 9:00 pm
by DarrenAnton
Thanks !!
