Orion how to set factory home position
Posted: Fri Dec 26, 2014 11:22 am
by todh
As a novice I did a dumb. As I was about to print a new model, the nozzle was too high. I went to the Z position (237.4) and added 1 mm. I am unsure if this was OK or dumb. I next went the set the Z position and set it. This was dumb!! I am unable to get the unit to find the home position so I can start over to set the Z height correctly. What is the procedure to reset the factory home position? Help.
Re: Orion how to set factory home position
Posted: Fri Dec 26, 2014 2:00 pm
Have you tried moving the nozzle down to paper height above the glass and then doing the Z set?
Posted: Fri Dec 26, 2014 3:10 pm
by BenTheRighteous
The latest Rostock MAX build manual has instructions for how to calibrate your Z height.
Posted: Sat Dec 27, 2014 1:03 pm
by todh
Eaglezsoar wrote:Have you tried moving the nozzle down to paper height above the glass and then doing the Z set?
I tried this but the nozzle wants to crash into the base when home is pressed.
Posted: Sat Dec 27, 2014 1:04 pm
by todh
Where do I find the settings for the Orion printer?
Posted: Sat Dec 27, 2014 3:38 pm
by todh
Thanks for all the help. I finally got it working correctly by resetting the Z height to the proper value. I am back to work and I love this printer!
