NASA Wrench
Posted: Sat Dec 27, 2014 5:44 pm
by jebeddo
Don't know if anyone saw that NASA released their STL file for the wrench they printed in space.
Printed one a few nights ago.
A really neat thing to print, and fully functional too!
http://nasa3d.arc.nasa.gov/detail/wrench-mis
Re: NASA Wrench
Posted: Sat Dec 27, 2014 6:19 pm
by BenTheRighteous
It has moving parts, right? Did they work right off the bat or did you have to fiddle with it first?
Re: NASA Wrench
Posted: Sat Dec 27, 2014 6:22 pm
by jebeddo
Yes, it has internal parts that I had to fiddle with for it to work.
I could see around layer 10 my edges on the internal parts started to curve, so I didn't expect it to work at all.
I was able to use my Xacto knife the cut the stuck parts without damaging the unit. I then just put an adjustable wrench on the head of it and turned. That freed it right up.
Re: NASA Wrench
Posted: Mon Dec 29, 2014 12:36 am
by Jimustanguitar
The MakerHive guys made one. Glenn printed it the same day that we noticed that the files were posted.
Here's a rendering that I made of the parts inside:
[img]
http://i.imgur.com/4nxqhT9.png[/img]
Link to discussion and video:
http://makerhive.proboards.com/thread/9 ... sas-wrench
If it's a useful tool, they ought to make the torque lever inside interchangeable so that they could print 1 wrench and multiple torque inserts.
Re: NASA Wrench
Posted: Mon Dec 29, 2014 7:52 am
by barry99705
I didn't realize it was a torque wrench. I thought it was just a 3 inch ratchet.
Re: NASA Wrench
Posted: Mon Dec 29, 2014 9:37 am
by teoman
I must print that. Just what I needed for some of my motorcycle maintenance tasks.
Re: NASA Wrench
Posted: Mon Dec 29, 2014 11:51 am
by Eric
3 in-lb = 0.25 ft-lb = 0.339 Nm, which is way too loose for nearly all terrestrial tasks. I have to wonder what their specific application is in space.
Of course, fairly accurate higher torques could easily be achieved through procedural means, when you have the kind of detail Nasa has on every fastener. Something like: "Tighten to 3 in-lb with the plastic ratchet/torque wrench, then tighten an additional 1/4 turn with the bar wrench."
Re: NASA Wrench
Posted: Mon Dec 29, 2014 2:00 pm
by jdurand
It's NASA, "tighten an additional 0.2499576 turn". I worked on space stuff.
Re: NASA Wrench
Posted: Wed Dec 31, 2014 8:26 pm
by MrJoe
I've had a hard time getting the torque lever to stick to the bed. Using glue stick on glass bed, Rostock Max V2, silver PLA, 210°C extruder, 60°C bed, printing at default MatterControl settings and also when printing slower. Bed is level, height seems good (first layer is squished nicely). After the third pass the torque lever loses it's grip on the bed and moves. I let the first one finish and the rest of the print looks good and the ratchet works but not as precisely as designed.
I'm very impressed with the de
sign of this wrench and it's suitability of 3D printing. I guess rocket scientists are very smart
Edit: Switched to a different spool of PLA and increased the first layer thickness and got good results.
Re: NASA Wrench
Posted: Thu Jan 01, 2015 7:25 pm
by teoman
Dayng. I needed 4Nm. Got the specs confused.
Re: NASA Wrench
Posted: Sat Jan 03, 2015 10:04 am
by oklok
Challenge accepted! This however should be printed with POM or some stronger material.
