Smart ABS - feedback
Posted: Mon Dec 29, 2014 3:46 pm
by enggmaug
I recently bought some Smart ABS from Orbi-Tech.
It is advertised as being some kind of revolutionary ABS, with low warpage, and high layer adhesion, with lower delamination than regular ABS.
I print it at 220°C, just as I do with ABS.
It actually warps much less than regular ABS, but still much more than PLA.
I don't feel like it has better layer adhesion, with less delamination than regular ABS.
The surface aspect is one of the best I have ever seen, it's a kind of matte finish, really really nice looking.
I print it with a .25mm nozzle, 0.1mm layer thickness. Didn't try anything else.
Apart from that, I would still not recommend it to anyone, as it will not bridge at all. Meaning, if you print with lower density than 100%, you get poor results. The plastic will not manage to cover the gaps.
As this filament is quite expensive, I don't think it is really acceptable.
If anyone tried it successfully, I would be glad to know which parameters were used.
