.stl file for spool upgrade ?
Posted: Mon Dec 29, 2014 11:30 pm
by darkjorik
i have a trouble.
In Ukraine filament made with cardboard spool. It's no good for MDF spool holder.
No slip. Cardboard spool can be damaged.
Maybe some one can give me .stl file for spool upgrade ?
Re: .stl file for spool upgrade ?
Posted: Mon Dec 29, 2014 11:49 pm
by Earthbound
This fits over the stock arm and provides a smooth surface that should work for cardboard spools.
http://repables.com/r/204/
Posted: Tue Dec 30, 2014 12:09 am
by BenTheRighteous
I found that model a few weeks ago. Honestly, that should be everyone's third print, right after the two fan shrouds!
Posted: Tue Dec 30, 2014 2:24 am
by darkjorik
this is joke ? :shock:
look like impossible print.
Who made this ?
i try print whith glue stick and skotch.
There is not good idea.
Too little space on the bed for too big model. :evil:
Posted: Tue Dec 30, 2014 3:02 am
by Earthbound
Print it standing on end.
Posted: Tue Dec 30, 2014 10:18 am
by BenTheRighteous
Yeah, you have to pick the right end though too.
One of the ends has a 90 degree corner. That's the bottom. The other end has a curved corner. That's the top.
Posted: Tue Dec 30, 2014 4:09 pm
by darkjorik
How i can rotate model ?
Posted: Tue Dec 30, 2014 4:29 pm
by BenTheRighteous
Are you using MatterControl? There should be an Edit button somewhere once you load the model. It has controls for rotating.
Posted: Tue Dec 30, 2014 4:45 pm
by darkjorik
I'm use MatterControl 1.2
when i push the Edit i see : Export, Copy, Remove. Nothing more
Posted: Tue Dec 30, 2014 4:51 pm
by darkjorik
I found this button in a view section.
Can I build this model with ABS or i need PLA ?
Posted: Tue Dec 30, 2014 6:20 pm
by Captain Starfish
ABS would be my preference, but either should work fine.
