Frozen ABS and switching between ABS and PLA
Posted: Tue Dec 30, 2014 9:31 am
I received a Rostock Max v2 for Christmas and just finished the build yesterday. I'll be doing the calibration today and would like to run at least a test print tonight.
So I have two questions:
1) Right now I only have some PLA meant for the Replicator that I picked up at Staples . If I try a few test prints with that and then want to switch to ABS, do I need to have a second print head or can I switch back and forth between ABS and PLA? What is the procedure for switching back and forth?
2) I live about 70 miles from the nearest place I can buy ABS, so I ordered some from Amazon. Unfortunately, due to the timing I expect it will spend 12+ hours sitting outside in 10-20 degree Fahrenheit weather. Will this ruin the ABS or will it be ok if I let it come back to room temp before using it?
tia,
John
tia,
John
