Iphone 6 NinjaFlex Cell Phone Cover !!!!
dunginhawk
Post by dunginhawk »
So after a LONG couple of days dialing things in, changing settings, blowing fans on steppers etc etc etc, I FINALLY got a ninjaflex to print on my Rostock N Roll.
I can certainly post some settings and tips/tricks I used to get it right, but honestly, its only the first success I have had, so its no where near my Bible yet... Ill share anything if you need it though.
Below are a few images.
There will always be a little bit of stringing with 0 retraction on Ninjaflex, but the only stringing I had was in the speaker and button holes.. easily trimmed.
Oh, and the black lines are from me marking the filament with a sharpie to make sure i was getting accurate extrusion.
[img]http://i1132.photobucket.com/albums/m562/dunginhawk/SAM_0219_zpsf484db0b.jpg[/img]
The phone fits like an absolute GLOVE in this thing. its perfect. Snug, protective, and feels great in the hand.
[img]http://i1132.photobucket.com/albums/m562/dunginhawk/SAM_0218_zps62f5c8a5.jpg[/img]
I really couldnt be happier with how this turned out. Except EVERY little imperfection on the bed (glue heights, scratches, etc) will ALL manifest themselves on the back of this case..
[img]http://i1132.photobucket.com/albums/m562/dunginhawk/SAM_0216_zps4d5ec458.jpg[/img]
Thanks for stopping by.. :)
BenTheRighteous
Re: Iphone 6 NinjaFlex Cell Phone Cover !!!!
Post by BenTheRighteous »
Looks awesome!
Did you have trouble getting the case on the phone?
I printed a phone case using Soft PLA from Matter Hackers and while the material is flexible, it doesn't stretch at ALL, so fitting it was a challenge.
Is ninja flex superior in that regard?
BenTheRighteous
Also, how did you print the lip of the case? Did you just print support like usual and remove them? Was it easy/hard and did it leave scarring?
dunginhawk
Fits perfect... i could scale it down by 1% and it would be REALLY snug...
This stuff cools quickly, so no need for support, the lip is perfect.
I had issues with PLA and ABS shrinking, so any case I made with those wasnt any good.
This stuff is great...
ninjaflex is VERY superior for this purpose.
BenTheRighteous
No support?? Is the lip a 90 degree overhang?
dunginhawk
No. It's more like a 45.
Generic Default
Post by Generic Default »
That thing looks nice! Were you using glue stick to hold it down during the print? There is a new method of mixing a glue stick with water and foam-brushing it onto the plate that is much better and leaves a smooth finish.
I've printed a few phone cases with trimmer line nylon, PLA, and ABS, but the flexible stuff would probably be the best for a protective case. Good job.
Check out the Tri hotend!
