First Print Results and Questions
Posted: Thu Jan 08, 2015 12:18 am
The first print of my Rostock max was surprisingly exhilarating, I was way too excited for this.
But here are a couple apparent problems with my first print (that I ended up having to abort).
1. When priming the hot end, how soon before it drops onto the bed should I take the little piece of dried ABS off of the end? I took some off roughly 50 seconds before it dropped to print, and it seemed to have a little trouble coming into its first layer.
[img]http://i.imgur.com/6JjcO9A.jpg[/img]
2. I had an issue with a lack of adhesion on the right side of the duct. There seems to be a small indentation (roughly 0.36”/9.24mm in length on the outside wall of the print) in the area where I think it would have started that part of the print, other than that I am unsure of what would have caused that defect in the part.
[img]http://i.imgur.com/tZV6iTS.jpg[/img]
3. It seemed to end up dealing with the lack of adhesion quite well in the next few layers, so I pressed on. As it built up to the layers extending the clip sleeves(?) to wrap them around and extend them outwards, they curled out a couple of boogers for about the first three layers, then finding some support, continued with a solid print.
[img]http://i.imgur.com/A5FdKfZ.jpg?1[/img]
4. Next, Catastrophe. Unfortunately I was getting a little cocky and was not paying attention to the print at this point, one second I see a beautiful print, the next it’s completely separated from the platform and is being dragged around by the hot end.
#1 is the part I think that stuck to the hot end and caused it to follow the hot end.
[img]http://i.imgur.com/jabVGBz.jpg?1[/img]
#2 is an interesting indication of some type of bad extrusion, I am completely at a loss to what could have caused it.
[img]http://i.imgur.com/LEiptGq.jpg?1[/img]
[img]http://i.imgur.com/DwIgMDF.jpg?1[/img]
5. Finally are a few small things, it looks like I need to re-calibrate and not give such a tight tolerance when putting the nozzle on the bed, as the base layer is really flat/squished down.
There are definitely other issues with the print as well, but I think the main goals as of this point are to get the print to make it all the way to finish, as well as fix my minor calibration issue until I can provide tooling for a more accurate calibration check to be performed. I am still calming down from this watching this beautiful machine do its work, as well as my victory beer. Yes, i am now realizing that natural color ABS was not the best choice to start out with for trouble-shooting, but it's what i have. lol
Also, sorry for the vertical pictures, they are all taken from my phone...
Thanks to you all in advance for your help and suggestions!
[img]http://i.imgur.com/ZUm5Cvt.jpg[/img]
ART
ART
