Kapton + Hair Spray
Posted: Sat Jan 17, 2015 9:38 am
by dunginhawk
So i am looking at a couple larger prints that simply wont stick with just kapton (i dont think anyway). Is it ok to use hair spray on kapton?
Or the Glue stick water mix? Will there be any issues ruining the kapton?
Just need to get an 8x8 item to stick and not curl up.
thanks
Re: Kapton + Hair Spray
Posted: Sat Jan 17, 2015 9:58 am
by DavidF
if its an abs print the best thing i have found on large prints it to make some abs glue and use it. Pla I just use glue stick.
Posted: Sat Jan 17, 2015 10:34 am
by dunginhawk
ive never made abs glue..
think running the bed up to 110 c would help as well? i have a couple different printers so im just weighing options
Posted: Sat Jan 17, 2015 10:50 am
by DavidF
dunginhawk wrote:ive never made abs glue..
Yes higher beds temps help as well, so would an enclosure. whats the dimensions of the part to be printed?
Posted: Sat Jan 17, 2015 10:57 am
by dunginhawk
8x5 x 1.5 inches.
I could use my 2nd printer which is fully enclosed and has the ability to get to 110c pretty easy on the bed...
im trying to prevent maybe having to do abs glue
but i know thats not likely.
Posted: Sat Jan 17, 2015 1:12 pm
by dunginhawk
So if i wanted to use abs slurry, im cool with that.... i want to keep the surface of the print (bottom) looking good, so ill try to smooth the slurry.
once thats done, how do I clean off the abs slurry from the kapton? just more acetone?
Posted: Sat Jan 17, 2015 1:26 pm
by aehM_Key
For me the best is still: 2/3 beer + 1/3 isopropyl alcohol
Heatbed at 120°C.
Posted: Sat Jan 17, 2015 2:04 pm
by dunginhawk
drink the beer use the alchohol? or are you serious? haha
Posted: Sat Jan 17, 2015 2:16 pm
by aehM_Key
I'm serious!
I tried hairspray, kapton and ABS glue, but this worked best for me.
Parts popp off at around 70°C. Heatbed can be cleaned with water from time to time.
Posted: Sat Jan 17, 2015 3:15 pm
by dunginhawk
Are you using that as glue or cleaner? sorry, there are a few questions happening here..
last question was how to clean ABS glue
Posted: Sat Jan 17, 2015 3:38 pm
by aehM_Key
As glue.
(Sorry, haven't read your question..)
Posted: Sat Jan 17, 2015 3:47 pm
by DavidF
I just scrape it off with a razor blade, but you can clean it off with acetone as well.
