				Just Fits (Part Daddy in Trailer)
				Posted: Mon Jan 19, 2015 8:30 pm
				by ZionPhil
				Re: Just Fits (Part Daddy in Trailer)
				Posted: Mon Jan 19, 2015 10:28 pm
				One more inch and  the door would not close.  Great that it did fit!
				Posted: Fri Feb 06, 2015 9:30 pm
				by johnoly99
				prob. less than an inch even!  The rubber feet need to be removed, or the doors don't close
				Posted: Fri Feb 06, 2015 10:12 pm
				by Tonkabot
				Your problem is that you need one of these, and a printer to fill it:
https://www.dropbox.com/s/3cjyspp8jl4uc ... _.jpg?dl=0
				Posted: Fri Feb 06, 2015 10:24 pm
				by timothysvec
				You're not straight out'a Compton.....Your straight out of the trailer!  Good luck guy's!   Also does anyone know how many amp's a 12 volt heater cartridge pulls.  i'm going to try to mod my seeme for those.
				Posted: Sat Feb 07, 2015 12:40 pm
				by Tonkabot
				I thought they are rated at 30W, so   2.5 A.      I = P/V        (E is the same as V)
[Edit]   So if they are 40W, that's 3.3A
[img]
http://upload.wikimedia.org/wikipedia/c ... _chart.svg[/img]
				Posted: Sat Feb 07, 2015 3:29 pm
				by jdurand
				The ones I've seen are 40W.
Just remember, small changes in voltage lead to big changes in Wattage.  That's why I have #4 (5.2 square mm) wire for my small solar panels, our building code understands this.
A 10% decrease in voltage is a 19% decrease in Wattage!
Doubling the voltage is a 400% increase in Wattage.
				Posted: Sun Feb 08, 2015 10:20 pm
				by timothysvec
				Thank's .... I put one of those heater cartridges in my seeme hot end .... And now ... My power supply fan run's... All the time.
