Trick for getting ABS off of PEI
Posted: Tue Jan 20, 2015 7:17 pm
by jarek319
Hi guys! After reading about the trouble a lot of people have about getting print off of PEI, I wanted to share a trick I discovered while puzzling it myself. All you need is a pair of diagonal flush cutters, which most electronics folk use for cutting component leads after soldering. All you do is use the flush cutters to pry the piece up at a corner like so, then use a spatula to peel the rest of the part of. Easy
http://imgur.com/gallery/95Yj2
Re: Trick for getting ABS off of PEI
Posted: Thu Jan 22, 2015 2:33 am
by teoman
I do not know why but when my pei cools down, the parts are completely lose. I only have to force them if pei is still hot.
(I print at 115 degrees as measured by the thermistor)
Posted: Thu Jan 22, 2015 9:47 am
teoman, that is exactly how PEI works. Let it cool and the part should pop off. I use a can of "electronics chill" to zap tough parts and that works great too.
Posted: Fri Jan 23, 2015 1:08 am
by jarek319
Is PEI meant to go to temperatures as high as 115?
