Rudder pedal...
Posted: Thu Jan 22, 2015 9:16 am
It's a two part casting - here's the main portion:
[img]
http://www.geneb.org/images/pedal-casting.jpg[/img]
Printed with 2+ year old Sliver ABS @ 220C with an 80C bed. No warp, no split. Ambient was about 63F.
My only complaint was the support printed by Kisslicer was insufficient for one spot. It's also pretty sporadic and "rotted". Not sure why.
Re: Rudder pedal...
Posted: Thu Jan 22, 2015 9:23 am
by bvandiepenbos
hairspray or glue stick on glass?
I actually have had decent results with the newest Slic3r generated support.
Re: Rudder pedal...
Posted: Thu Jan 22, 2015 10:30 am
I've got one of those electronics rulers. Works better than a banana for scale
Re: Rudder pedal...
Posted: Thu Jan 22, 2015 10:56 am
Glue stick. I haven't touched Slic3r in a long time. My go-to has been Kisslicer (old version) and MatterSlice.
The ruler was an after thought.
Re: Rudder pedal...
Posted: Thu Jan 22, 2015 11:02 am
by DavidF
I was expecting a ninjaflex print Damn dislexia!!
Re: Rudder pedal...
Posted: Fri Jan 23, 2015 8:28 am
*mumbles something about rubber biscuits*
Re: Rudder pedal...
Posted: Fri Jan 23, 2015 12:54 pm
by barry99705
DavidF wrote:I was expecting a ninjaflex print Damn dislexia!!
Trojan brand flexible filament.
Re: Rudder pedal...
Posted: Fri Jan 23, 2015 9:29 pm
Looks good Gene and I'd like to see a picture of the part attached and in use.
Re: Rudder pedal...
Posted: Fri Jan 23, 2015 9:57 pm
by barry99705
Eaglezsoar wrote:Looks good Gene and I'd like to see a picture of the part attached and in use.
There's no way in hell I'd trust a printed rudder pedal. Now once it's molded and cast in aluminum, that'd be cool.
Re: Rudder pedal...
Posted: Mon Jan 26, 2015 11:34 am
That won't ever be cast - at least not by me. Even if I printed it at 100%, it would be too structurally weak to leave in plastic. I'm going to create a hybrid design that uses 12mm Baltic Birch for the pedal and ABS printed heel caps.
Re: Rudder pedal...
Posted: Mon Jan 26, 2015 11:50 am
by Chrissi
I think the Warbirds guys would be going spastic if you had this going in a booth in the Warbirds area at Oshkosh. They'd be knocking themselves out trying to guess what it was where it goes.
Re: Rudder pedal...
Posted: Mon Jan 26, 2015 12:34 pm
It's a rudder pedal for a Bf-109K4.
I'm going to be printing a couple of bellcranks for the pitch control system later in the week.
Re: Rudder pedal...
Posted: Mon Jan 26, 2015 4:12 pm
geneb wrote:It's a rudder pedal for a Bf-109K4.
Will the finished product be able to fly?
Re: Rudder pedal...
Posted: Tue Jan 27, 2015 9:54 am
No. I'm only building 2011mm worth of K4.
Re: Rudder pedal...
Posted: Tue Jan 27, 2015 7:56 pm
by barry99705
geneb wrote:No. I'm only building 2011mm worth of K4.
Wonder how much plastic pellets it'd take partdaddy to print out the front 6 feet?
Re: Rudder pedal...
Posted: Tue Jan 27, 2015 9:30 pm
by 626Pilot
You can never have too much structural integrity in an airplane part. I had a toe brake shear off once. Fortunately, I was just on a taxiway. If I had been trying to slow the airplane after landing and that happened, it could have lead to a loss of control. Every now and then I'd hear about some pilot somebody knew that died. One or two were taking off in IFR and their gyro spun out, and they didn't have a backup - they crashed in a graveyard. I knew a mechanic who worked out of a wheelchair because a skydiving plane he was in had an engine go out in a critical moment of the takeoff phase. The pilot stomped on the rudder to correct - but he used the wrong pedal, and that was it. They say 80% of the time it's the pilot's fault, but that last 20% isn't for nothing.
Re: Rudder pedal...
Posted: Wed Jan 28, 2015 4:34 am
by bot
I think gene won't have to worry if this one breaks. He could just jump out of the cockpit at 10,000 feet without a scratch on him.
Re: Rudder pedal...
Posted: Wed Jan 28, 2015 7:21 am
bot wrote:I think gene won't have to worry if this one breaks. He could just jump out of the cockpit at 10,000 feet without a scratch on him.
If he has a parachute and the right wind direction.
Re: Rudder pedal...
Posted: Wed Jan 28, 2015 8:21 am
Reminds me a of a pretty bad joke....
"Did you hear about the Cessna 152 that went down in a graveyard in Poland? They've recovered 69 bodies so far and there's no end in sight."
*grins, ducks & runs*
Re: Rudder pedal...
Posted: Wed Jan 28, 2015 12:11 pm
by Mac The Knife
geneb wrote:Reminds me a of a pretty bad joke....
http://instantrimshot.com/index.php?sou ... &play=true
Re: Rudder pedal...
Posted: Thu Jan 29, 2015 9:43 am
Thanks! I'll be here all night!
