Another Rostock Comes to Life
Posted: Thu Jan 22, 2015 1:55 pm
by koontzrd
My Rostock lives!!!!
This was a really fun and challenging project - (I had never soldered before) But the instructions were straightforward and I felt that they were easy to understand.
I did make a couple of mistakes putting it together including:
1) I put the screws that hold the plexiglass corners into the wrong side of the boards and then had to find a way to get them inside the machine after everything was put together.
2) I learned that you should turn off the machine before installing the peak fan - and blew one of the tiny fuses on the Rambo Controller.
But everything is up and running now!
Also, I added a reversible USB genderchanger: http://www.amazon.com/gp/product/B003VS ... UTF8&psc=1 as a USB port and ran a short USB cable inside from the port to the Rambo. That way I could plug and unplug the USB cable without opening the panel.
Re: Another Rostock Comes to Life
Posted: Thu Jan 22, 2015 9:46 pm
by jram
Nice work! Thanks for posting the link for the USB piece.
Posted: Fri Jan 23, 2015 8:21 am
Yes, thanks for posting that link! I've been looking for something similar for a while (RJ45).
Posted: Fri Jan 23, 2015 5:59 pm
Very good job in using the USB genderchanger.
I will be getting one of those!
Posted: Sun Feb 01, 2015 7:49 am
by 3D-Print
Love the USB connect. Just ordered one. This will prevent over manipulation of the Rambo and damage.
Of note your link points to an "A-to-B" feed through where as you really want a "B-to-A" feed through.
Thanks. Dan
Posted: Thu Feb 05, 2015 10:09 pm
by 3D-Print
Added the B-to-A USB to my printer tonight.
Thanks for the idea....... Will save my Rambo board.
