since yesterday my RMV2 is running, more or less.
I was able to get 1.5 good prints out of the machine.
--> who designed that "home towers" button next to the speed setting???
The problem:
it seems that there is very few material coming from the nozzle. Especially at starupt it is definitely not enought. After some loops, there is a "ok" amount of material, so was able to get the (really) good prints.
At my second print atempts (layer fan duct) i got the hotend jammed. So i fixed this, and restarted the print. It worked all pretty well, but due to a Bluescreen i was not able to finish the print tonight.
I tried to restart the machine this morning, but couldn`t get it working.
I am printing ABS with 250C nozzle and 90C bed. The printer is stock.
It seems that the extruder is permanently slipping.
What i don´t know is the reason.
Is the hotend to cold?? (if i feed material manually by hand, there is a quite strong resistance. But The nozzle is free)
Is the extruder wrong/weak? ?
I tried to readjust the extruder wheel yesterday. So today it is for sure aligned right. There is some ABS residue on the whell.
If i assist the extruder (manually feeding material to the extruder while it´s running) i get more/better flow from the nozzle, but what is the reason?
What else affects the filament flow?
Thank you for help
