Plexiglass Enclosure for Rostock 2 -- Any Suggestions?
Posted: Wed Jan 28, 2015 2:00 pm
by HesDeadJim
I would like to be able to install plexiglass / acrylic walls and a hinged door around my Rostock Max 2 machine as an enclosure and I "thought" there were some printable clips/brackets that someone had designed to install such a thing but I can't seem to find them. Was I imagining things? Perhaps someone here might know where I can find what I'm looking for. Anyone heard (or imagined?) of these brackets/clips? Any assistance is always appreciated. Thanks!
Re: Plexiglass Enclosure for Rostock 2 -- Any Suggestions?
Posted: Wed Jan 28, 2015 2:25 pm
by BenTheRighteous
Here's one. I just built it & I like it, but I am still looking for a layer fan that won't smack into the wall...
http://forum.seemecnc.com/viewtopic.php?f=42&t=7149
In fairness, you'll probably have the layer fan problem no matter which enclosure you wind up going with.
Posted: Wed Jan 28, 2015 10:47 pm
by jram
BenTheRighteous wrote:Here's one. I just built it & I like it, but I am still looking for a layer fan that won't smack into the wall...
I recently had the problem of the layer fan running into my enclosure. I'm working on cutting out a section of the acrylic panel and then printing a bump out so the fan travels inside of the bump out, should be done soon. Not sure though if it's the easiest solution..
Posted: Wed Jan 28, 2015 11:35 pm
by BenTheRighteous
I guess I'm not entirely sure what you're describing, but I'd certainly like to see your approach when you can post some pictures!
I tried to design a new fan shroud that wedged the squirrel fan flat underneath the effector. It (almost) worked, but in that case you're trading one problem for another - the fan hits the binder clips instead of the polycarbonate.
I'm still noodling on if I can come up with a better solution...
Posted: Thu Jan 29, 2015 9:01 pm
by HesDeadJim
Thanks for the link! I KNEW I had seen something!
Posted: Thu Jan 29, 2015 9:15 pm
by JFettig
I'm super happy with the enclosure, I taped up all the holes into the build chamber to keep air from cycling and it stays up close to 40C on its own, no more cracked ABS prints!
Posted: Sat Feb 07, 2015 8:57 am
by hugepanic
What do you think of my version?
It´s not plexiglass but 0.8mm PET.
it is just a cylinder with some holes in it to open the casing.
The holes fit to two extended screws from the top assembly.
It`s super simple and inexpensive.
Posted: Sat Feb 07, 2015 8:28 pm
by KAS
I'm currently printing JFettig's enclosure although I mostly print PLA and will have to come up with a fan design that works. ( if the one im using doesn't)
I haven't measured to see how close the fan I'm using comes, it might just work as it is. (
http://forum.seemecnc.com/viewtopic.php?f=35&t=2854 )
