a few quick newb questions
Posted: Thu Jan 29, 2015 11:47 am
Hi all! Ive bene having problems finding the I need in the forums, thanks in advance for any help.
The slic3r settings downloaded from seemecnc.com have PLA heated to 210. Why is that? I thought PLA should be heated to 180 ish.
The site lists the maximum bed diameter as 150mm, but the settings come with 200mm. 150mm seems too small since I've printed several thing bigger than that on accident, what's the actual size?
I have a version 1 Orion, is adding a cooling fan as easy as attaching the blower to the wires up top and printing a shroud? Will it support 2 fans?
I'm about to build a rostock max v2, but I want to use the e3d v6 and volcano I've been reading about in the forums. Are the Rostock max and orion 12v or 24v? How would i find this kind of thing in the future without hassling people in the forums? I looked in the manual and on the specs on the site. Should i just crack open the printer and look at the electronics?
