Power Supply?
Posted: Fri Jan 30, 2015 6:14 pm
by VTOLmotors
My power supply does not seam to have the 6 pin as shown in figure 3-17. These are supposed to be for the RAMBo board. What do I do?
Re: Power Supply?
Posted: Fri Jan 30, 2015 6:29 pm
by Earthbound
You can get the yellow and black wires from any remaining connector. Gene used that particular one because it was convenient having only the colors needed. I'd use the thickest yellow and black wires that haven't been utilized in the earlier steps.
Re: Power Supply?
Posted: Fri Jan 30, 2015 8:04 pm
by VTOLmotors
OK, thank you. I will try that.
Re: Power Supply?
Posted: Fri Jan 30, 2015 8:25 pm
by VTOLmotors
So there are groups od black yellow and black red. Is red the same as yellow or does it have to be yellow?
Re: Power Supply?
Posted: Fri Jan 30, 2015 8:37 pm
by Mac The Knife
Black is common. Yellow is +12 volts and red is + 5 volts. Use the yellows.
Re: Power Supply?
Posted: Sat Jan 31, 2015 9:48 am
by teoman
You may have problems if you use red.
But keep a couple of red black and yellows handy. You may want to attach stuff like LEDs etc later on.
