Rattling Vibration Noise
Posted: Fri Feb 06, 2015 2:08 pm
Helllo,
I have been printing with my Rostock Max V2 for ~6 months now. I have been noticing an increasingly obvious rattling/vibration noise during my prints. Print quality is not affected, but it is starting to get annoying and I would like to make sure there isn't a more serious underlying issue. The rattling only occurs when printing on the 240 degrees from Z tower -> X tower -> Y tower (it doesn't rattle when printing in the 120 degrees between the Z and Y tower). My equipment/conditions are:
- Rostock Max V2 (Stock, no upgrades)
- Rev 6 heated bed
- Repetier-Host with Slic3r
To date I have tried the following to determine/eliminate the issue without success:
- Removed glass bed and binder clips. Dry ran a program.
- Manually changed %feedrate from 50-200 while it was running to see if it was stepper motor related
- Checked/snugged screws holding the heated bed pcb down.
- Lifted heated bed pcb and checked for loose wires.
- Tightened jam nut retaining hot end in its housing
- Checked hot end resistors.
- Removed power supply and checked for debris inside of the power supply housing.
- While the program was dry-running (no filament and heaters off), I pushed in areas on the carriages, hot end, and bed to see if the sound increased, decreased, or was eliminated.
- Checked layer and shroud fans.
- Checked general fastener connections (haven't found any loose yet).
- Checked (4) screws that fasten the RAMPS board.
- Currently all side covers are removed.
As I said above nothing that I have done yet has even changed the sound of the vibration. It seems like it has to be related to the bed/base since it so clearly stops in that one area of the bed. Any advice is appreciated. Thanks.
- Rev 6 heated bed
