Thermistor Tuning?
Posted: Fri Feb 06, 2015 7:59 pm
Quick question regarding the thermistor temperature reading.
With the v2 stock hotend I made an excel chart of the different filaments I have and the temperature I used to print. Both on plain glass for PLA and diluted glue stick for ABS. (around 220c/70c for PLA)
When I switched to the E3D V6 and the .4 Nozzle, I noticed that I wasn't getting the same results in regards to bed adhesion. After a few PID autotunes nothing has changed except for the increased values I have to use for the hotend to make the filament stick.
I broke out the Fluke 1587 with thermocouple probe and stuck it directly on the heater and showed I was consistently getting 12c cooler temps than what the thermistor was picking up between various ranges from 200-240.
Question: Is it possible to offset this value to correct reading or is it just something I should live with and adjust my chart to the new values?
