Upgrading Heater Bed
Posted: Sun Feb 08, 2015 3:46 pm
Hello,
I am planning on buying a Rostock Max v2 within a couple of weeks here and I just want to prepare for some upgrades. I have read a lot of reviews about the Rostock Max v2, and I have heard good things. I had a couple of questions regarding upgrading the heated bed.
I am going to buy a 24V power supply to hook directly into the bed. The heated bed outputs 130W of power, so I figured 300W would be more than enough for me. I found a Meanwell NES-350(350W) for $52.99 on amazon. Is this a nice model? Is it going to fail on me?
I understand that the heated bed will draw ~22A and the PSU can only handle 14.6A. This means I will need to use PWM to bring it down, but doesn’t that still draw 22A just in little spurts? Is this going to break my power supply?
Since my goal is to output 300W from this power supply, this amounts to 12.5A. This is ~86% of the maximum current, and I have read that it is best to stay under 80%. Should I upgrade to a better power supply? Will running at 85% destroy my power supply in the long run?
I have also taken a look at SSR on the web. I noticed that these can be expensive since the relay has to dissipate large amounts of heat due to the large currents. I have found a 12V automotive relay that can handle 30A for $7. This uses an electromagnet to activate the switch, which requires no dissipation of heat such as a MOSFET or phototransistor would require. Is there any negative side to using an electromechanical relay instead of a SSR?
The only issue I currently see is that the automotive relays are meant to output 12V but I will be outputting 24V. If they don’t have enough spacing, then arcing could occur. I will have to dig around in the datasheets to see what the dielectric strength is.
I plan to upgrade the 12V power supply to a Corsair 430M and the dimensions of the 24V power supply are 215x115x50mm. Would these both be able to fit underneath of the printer? I would like to keep it out of the way. Would I need more fans for cooling?
I have a side question. I have heard from numerous people that it takes 15-20minutes for the heated bed to heat up to 100degC. My old printer(Prusa i3 rework 8” heated bed) took the same amount of time, and I measured 100W output for it, including voltage drop. When I increased the power to 120W and added some insulation, it only took 10minutes for it to reach 110degC. However, the rostock max heated bed should be receiving 120W as well, but it takes just as long as my 100W heated bed. I am neglecting that the rostock has a larger heated bed, no insulation, and the voltage drop across the terminals, but does that really make that big of a difference?
For others who have upgraded their heated bed, how much power and how quickly does your bed heat up?
Thanks for any help.
