Nonplanar Slicing
Posted: Tue Feb 10, 2015 6:56 am
by KAS
Looks interesting, almost like a subtractive cnc in reverse.
https://www.youtube.com/watch?v=M3Bwo0AVML0
[youtube]http://www.youtube.com/watch?v=M3Bwo0AVML0[/youtube]
Re: Nonplanar Slicing
Posted: Wed Feb 25, 2015 2:56 pm
by JackFoz
That's interesting! I've never seen that before. You'd be limited by the hotend somewhat because if the high point on the print but it'd be cool to see this working on the deltas. Thanks for the post.
Posted: Thu Feb 26, 2015 9:25 am
by briankb
Other than the limit between the hotend tip and its heatblock, as JackFoz said. It would make whatever you are printing much stronger. I doubt this would be practical for FDM unless you could make a long tip that sustains the heat needed without all the bulk... maybe a thick needle wrapped in ceramic or something and then adjust the temp to be correct at the end of the tip. tricky for sure!
Posted: Thu Feb 26, 2015 10:18 am
by Nylocke
Uhhh you mean the Volcano? Released earlier this month by e3d?
Posted: Thu Feb 26, 2015 10:24 am
by briankb
Nylocke wrote:Uhhh you mean the Volcano? Released earlier this month by e3d?
talking to me? because the Volcano has a pretty standard looking tip.
Posted: Thu Feb 26, 2015 10:33 am
by Nylocke
I misread your post, but I fail to see why a needle type tip would be needed for this? They are doing it on a standard E3D hotend in the video, and I don't see why the pitch of the slope would have to be so steep that the nozzle/heater block would collide with the part. If it's really that much of a concern the Merlin hotend could do alright, it uses airbrush tips as nozzles so they are needle like.
Posted: Thu Feb 26, 2015 7:33 pm
by Tonkabot
briankb wrote:Other than the limit between the hotend tip and its heatblock, as JackFoz said. It would make whatever you are printing much stronger. I doubt this would be practical for FDM unless you could make a long tip that sustains the heat needed without all the bulk... maybe a thick needle wrapped in ceramic or something and then adjust the temp to be correct at the end of the tip. tricky for sure!
why would it make what you are printing stronger?
