Marlin vs. repetier
Posted: Tue Feb 17, 2015 12:44 pm
by Behold
I would like to see people's opininons regarding the pros and cons of repetier firmware and Marlin firmware for the rostock. Well, at least I would like to see it in one place.
Anyone have any opinions on it?
Re: Marlin vs. repetier
Posted: Tue Feb 17, 2015 1:09 pm
I have observed that the majority of SeeMeCNC.com printer users who are also members of this forum use Repetier software and firmware and the given reason is that Repetier is smoother, Marlin has been rated as more "jerky".
Posted: Tue Feb 17, 2015 2:26 pm
I was the first customers that John installed the SeeMe branch of Repetier firmware on... I'd never printed before, so I have no reference for what it may or may not do better. At the time, everyone said it was quieter and smoother, and also that it could move the effector at a constant speed instead of the sinusoidal speeds that Marlin of the era was producing.
That was 2 years ago, though. I'd be very curious to see a current comparison of the two.
I've heard rumors about a few printer brands testing the water on switching back to Marlin because of political reasons and Repetier closing their IP.
Posted: Tue Feb 17, 2015 6:55 pm
by Nylocke
Ive tested more recent versions of Marlin (Joahnn's branch), I didn't test the main branch since it didn't have the auto leveling functionality at the time (this was a month ago). Johann's branch is pretty current from what I can tell (the config files were very similar to the main branch config files and I couldn't find any missing features). It was pretty stuttery. I didn't bother too much with it, I tried adjusting the segments per second and it didn't help much. I heard something about screwing the the acceleration and dropping the segments per second would smooth things out, but that didn't seem like a very good solution to the problem, so I just switched back. Marlin's motion planner isn't very good from my experience, I had stuttering issues on my Ultimaker at times as well.
That being said, I had good successes with the original Marlin build that they were running on the early V1 MAXs. It is quite old however.
Posted: Tue Feb 17, 2015 9:53 pm
I believe I was the first user at least on the forums to run repetier on a MAX, delta motion was still a beta feature in repetier at the timeat the time I think. I maintained a branch for a while before SeeMeCNC made the leap from Marlin. The original reason I swapped was Marlin had very poor delta motion at that time, and frequently paused mid move. But as has been mentioned that was over 2 years ago and I haven't done a recent comparison
Posted: Tue Feb 17, 2015 10:42 pm
by Nylocke
From what I've read on the github they are doing an overhaul on the code. Cleaning things up, unifying the branches, and fixing the motion planner and other things.
Posted: Wed Feb 18, 2015 1:45 am
by Khalid Khattak
I did this with latest version of Marlin Firmware . so far so good...never tried Repetier...
Posted: Wed Feb 18, 2015 10:06 pm
by Behold
i have another thread going about lcd controllers. It seems that most of the controllers with fancier lcd's use marlin firmware. I find that odd
Posted: Wed Feb 18, 2015 10:13 pm
by Nylocke
Fancier LCDs? The fancy ones I'm aware of are the Viki type ones and the Full Graphic one from RepRapDiscount. I'm fairly certain that Repetier has support for the Full Graphic display, and I know it has support for the Viki 1 display, I'm looking at a printer using one. I'm not super sure on the compatibility of Viki 2 with any firmware other than Smoothie though, but I'm sure that its being built into Marlin and Repetier, if it isn't already. Pretty sure all 3 firmwares support the more widely used LCDs.
Posted: Wed Feb 18, 2015 10:21 pm
by Behold
I'm speakung full graphic. I can't find the Viki in stock anywhere. However ( at least through amazon prime) the full graphic ones recommend marlin.
Posted: Wed Feb 18, 2015 10:22 pm
by Behold
Btw.. What's the 3rd firmware? Marlin, repetier and what? Thsnks
Posted: Wed Feb 18, 2015 10:33 pm
by Nylocke
Smoothieware, only runs on the Smoothieboard and the Azteeg X5 mini from what I know. They are faster and smoother (get the pun) running boards, with a better processor. The Viki 2 and the Full Graphic work natively with the smoothie powered boards from what I know, the other displays (Viki 1, Discount LCD, etc) need an arduino as a "middle man" to run with a Smoothie powered board.
Posted: Thu Jul 09, 2015 11:03 am
by dewme5
Anyone know where can I find the Marlin firmware for the Rostock Max v2, with the stock Rambo?
Posted: Thu Jul 09, 2015 2:47 pm
dewme5 wrote:Anyone know where can I find the Marlin firmware for the Rostock Max v2, with the stock Rambo?
https://github.com/seemecnc/Marlin-for-RostockmaxLCD
Posted: Fri Jul 10, 2015 12:35 pm
by dewme5
Posted: Fri Jul 10, 2015 1:32 pm
dewme5 wrote:
Thanks so much
You should realize that branch of the firmware hasn't been updated in over 2 years.
Posted: Fri Jul 10, 2015 5:13 pm
by dewme5
I was just reading over it, and noticed that 2 year mark. I think for now, I'll stick with the way it shipped, and possibly tinker later once I know what I'm doing.
Posted: Sat Sep 05, 2015 3:13 am
by Fiddler2070
Khalid Khattak wrote:I did this with latest version of Marlin Firmware . so far so good...never tried Repetier...
Hey khalid can you share your slice settings? Those prints look really good. Are you actually using the compressor pump print? Or whatever those bladed things are?
Posted: Sat Sep 05, 2015 8:41 am
by teoman
[img]
https://encrypted-tbn0.gstatic.com/imag ... 2p1rtUXlyw[/img]
