Hotend not responding
Posted: Thu Feb 19, 2015 10:53 pm
by jram
Hello All, What would be the first thing to check/repair if the hot end is not responding to inputs? Bed seems to be working fine if controlled by the LCD. As I type , the hot end has gone from 16.1 to 19.8 in 25 minutes. This is with an input of 160 on the LCD. Any help is appreciated.I tried a PID autotune but that wouldn't run.
Re: Hotend not responding
Posted: Thu Feb 19, 2015 10:55 pm
by Nylocke
Check what the PID drive max is set to, as well as the max PWM. PID max should be something like 230 and PWM max should be somewhere around 255.
Posted: Fri Feb 20, 2015 4:33 pm
by jram
Thanks Nylocke, I'll give that a look.
Posted: Sun Feb 22, 2015 10:59 am
Also check the small fuses found on the rambo.
