I bought a Deltaprintr through Kickstarter in 2013, and it arrived last week. It's an interesting little printer. Unfortunately, they decided to use Marlin firmware, and for some reason it just doesn't read the endstops right. The controller is an Azteeg, so I'm already wary it may be hosed.
The config is weird. They have three FSRs ganged together and hooked up to the heated bed temp port, and they use that for Z probing. Other than that, they have normal endstops at the top of the towers, just like any Rostock. I used a continuity tester to verify they're all functioning right, but when I type M119, the results are straight up bizarre!
This is what it says when the Z MAX (not min!) endstop is pressed:
21:54:32.865 : x_max: open
21:54:32.865 : y_max: open
21:54:32.868 : z_min: open
21:54:32.868 : z_max: open
This is what it says for all other combinations (X pressed or not, Y pressed or not, and Z not pressed):
21:54:36.976 : x_max: open
21:54:36.978 : y_max: open
21:54:36.980 : z_min: TRIGGERED
21:54:36.980 : z_max: open
So, X and Y will report open whether triggered or not; and if Z max is triggered, it makes Z MIN say open instead of triggered. This makes absolutely no sense to me. I flipped the endstop connectors around to see if that was it, but it made no difference.
Any ideas would be appreciated!
Anyone know why Marlin wouldn't read the endstops correctly?
Jump to
- SeeMeCNC Announcments
- ↳ General Announcments
- ↳ SeeMeCNC crew in the wild
- ↳ 3D Printing Contests
- ↳ Development Topics
- Software
- ↳ Orca Slicer
- ↳ SuperSlicer
- ↳ Cura
- ↳ Simplify3D
- ↳ Slic3r
- ↳ KISSlicer
- ↳ Repetier Host
- ↳ OctoPrint
- ↳ Other
- ↳ Sculptris
- ↳ OpenSCAD
- ↳ FreeCAD
- ↳ Blender
- ↳ SolidWorks
- ↳ AutoDesk 123D
- ↳ EMC2/LinuxCNC
- ↳ Skeinforge
- ↳ Mach3 Software
- ↳ MatterControl
- ↳ Creation Workshop
- ↳ Fusion 360
- General Forums
- ↳ New Member introduction
- ↳ The Lounge
- ↳ Live Stream Announcments
- ↳ Show us your machine!
- ↳ What are YOU making?
- ↳ General Tips 'N Tricks
- ↳ Troubleshooting
- ↳ Rostock MAX Official Docs
- ↳ ORION Official Docs
- ↳ GCode & Test Prints
- ↳ The Build Zone
- ↳ FAIL HAPPENS ! ! !
- ↳ Filament
- ↳ Test Forum
- ↳ Members Marketplace
- Extrusion Based Machines
- ↳ Artemis
- ↳ BOSSdelta 300
- ↳ BOSSdelta 500
- ↳ RostockMAX v4
- ↳ RostockMAX v3.2
- ↳ RostockMAX v3
- ↳ ORION
- ↳ ERIS Delta
- ↳ Hacker Series - H2
- ↳ Rostock MAX v2
- ↳ Rostock MAX
- ↳ H-1.1 3D Printers
- ↳ H-1 3D Printers
- ↳ Other Machines
- ↳ RailCore
- ↳ Scorpius™
- ↳ Constellation
- Regional Forums
- ↳ Sprechen Sie Deutsch
- ↳ Parlez-vous français
- ↳ Hablas español
- ↳ Australia and New Zealand
- UV Liquid Resin Printers
- ↳ DropLit
- ↳ Resin Materials
- ↳ Troubleshooting
- ↳ Development Ideas
- ↳ Skylight
- Hardware Store
- ↳ Nuts and Bolts
- ↳ Computer Hardware
- ↳ Mods and Upgrades
- ↳ Heated Bed How-To's
- Electronics
- ↳ RAMBo
- ↳ RAMPS
- ↳ Azteeg X3 and X3 Pro
- ↳ Beaglebone Black
- ↳ Duet
- ↳ Sanguino (lulu etc...)
- ↳ Gen6 and variants
- ↳ Printrboard
- ↳ Power Supplies
- ↳ Alligator Board
- ↳ Other Controllers
- ↳ OTHER Electronics
- SeeMeEducate
- ↳ Teachers Lounge
- ↳ Show Your Work
- ↳ Software Help
- ↳ Design Help
- ↳ Show and Tell
- SeeMeFPV MultiRotor Forums
- ↳ General FPV topics
- ↳ Motors
- ↳ ESC's
