For some reason the silicone tape I had wrapped around the hot end failed (split vertically), and pulled out the thermistor and the permatex copper sealant plug just a little bit. The hot end started moving when touching the bed during the calibration so about 1 second of troubleshooting along with the smell pointed to the problem.
What i didn't do is install the the threaded thermistor that I have on hand for my e3d hot end (but no mounting e3d plates yet so I'm stuck ordering then new peek insert). I didn't have an M3 - .5 bottom tap to do the mod on the stock hot end. So I now have an M3 - .5 bottom tap on order from amazon and 2 replacement peek inserts from the motherland!
Live and learn!
I would highly suggest to any new builders to get a ceramic heater cartridge, a threaded thermistor insert, and an M3 -.5 bottom tap as part of the "must have" items for the initial build. (I wish it was an option or a standard item on the original kit). The permatex sealant is such a messy, ugly, poor design IMO.
Sorry for the small rant
