Dirt cheap thermal barrier
Posted: Fri Feb 27, 2015 6:38 pm
I thought I'd post my quick & dirty thermal barrier mod for the Rostock. It's helped quite a bit in terms of minimizing issues with drafts and the interior temp seems to run ~10 degrees warmer. YMMV based on materials.
Anyway, it's a shower curtain, some metal perforated strip (often called "plumbers tape" - not teflon tape though), some zip-ties and a couple of bits of velcro. It turns out the screws used to hold the smoked plastic pieces in place just fit through the holes in the plumber's tape, so it was easy to thread a long strip around the inside and force it over the screws, making for a pretty stable perforated ribbon around the rim of the top. I then picked up a heavy duty vinyl clear shower curtain, cut it to size, and zip-tied it to the plumbers tape. Some velcro closures to hold the front shut and viola! Works quite well.
I was able to extend the plumbers tape out so that the curtain doesn't contact the carriages.
[img]http://i1072.photobucket.com/albums/w37 ... lpx3hf.jpg[/img]
[img]http://i1072.photobucket.com/albums/w37 ... xk6vyi.jpg[/img]
