GIANT Rostock Max v2 Build + parts list! 32" print height
Posted: Mon Mar 02, 2015 10:28 pm
I'll make this short and sweet for now, but please feel free to respond with questions if you have them and hopefully I'll remember to check back here soon.
In short, I build RoMaxes semi-professionally, and my most recent client wanted the freedom to print objects up to 24" tall. I said, sure, no problem. For around 100 dollars you can make the mods yourself, or build a new one (much easier) with my specs.
FINAL assembled height: well over five feet.
FINAL assembled build height: 32" OR 804.145mm
So what does one need to make this happen?
1. Longer extrusions.
2. Longer belts.
3. 18AWG, (you DO NOT need 22AWG) and 26AWG wire extensions
4. Longer PTFE bowden tube
And that's literally it!
1. Extrusions: McMaster Part# 47065T101 ($14.20 each - so 42.60 total)
2. Belts: Grab these from Ebay, just search GT2 timing belt 6mm width. There are lots of vendors selling by the foot or meter. You will need almost EXACTLY 27 feet of it. 9 feet for each tower. This gives you about 4-5 inches of extra play to help tighten them on the carriages. I bought 30 feet because it was so cheap. It cost about 30 dollars.
3. McMaster has LOADS of wire, and you'll want MM Part # 8054T11 (about 1 dollar per foot, get some black and red and maybe white if you want to match the endstop wiring) (or similar, but keep them thin, if ordering from anywhere else) for your 26AWG wire extensions. These are the most crucial, but you only need about 12-18 inches of extension! Solder well, friends! Then add heat-shrink. Believe it or not, I didn't need to extend the 18AWG wires. They came quite long by default and just barely made it to the RAMBo AND all the way up and down the massive extrusions. To make it easier, you can extend them by about 12-18 inches as well. Since the 22AWG wires only need to reach the top of the tower anyways, there is MORE than enough already included in the kit, even though you will cut off more than a foot to wire up the heated bed.
4. Tubing: McMaster Part # 52335K32 ($12.70) I bought 5 feet of tubing and cut it down by a little over a foot and a half. You can measure this more precisely on your own. I have 22 inches of the tubing left after the build, so that means I used 38 inches of tubing. Results may vary depending on the extruder and hotend you use so measure twice and cut once!
So that's a little less than 100 dollars? Or a little more if you buy extra 18AWG wire.
(I also ALWAYS replace the cheap power supplies shipped by default with high quality modular (saves on wire clutter) PSUs from EVGA. 500-600W is more than enough!) You can find them on Amazon or your favorite computer PSU vendor's shop. Corsair's offering in the lower-end aren't as nice as their higher-ups.
That's all there is to it, solder on your wire extensions as needed, which will leave the solder connections JUST below the X tower, giving you JUST enough room for the endstop connectors to reach their endstops. NEVER thread an extended wire through an extrusion. You can do all the extrusion-threading with the supplied wire. It's all long enough. Just add extensions where needed.
Thanks for reading!
[img]http://i.imgur.com/jx4H7UA.jpg[/img]
[img]http://i.imgur.com/nVAWU1d.jpg[/img]
[img]http://i.imgur.com/itSlaOb.jpg[/img]
2. Longer belts.
Thanks for reading!
