So to just jump right into things it seems like a mess of problems finally piled together for me, and I am sincerely hoping I could get some help from the community. The issues are as follows, and thank you so much for your help ahead of time!
Background Info:
- Rostock Max v2
- E3Dv6 Hot End Upgrade (0.25mm Nozzle) w/ Printed Mount pieces (http://repables.com/r/338/) & Metallic Spacers
- Custom Extruder fitting (http://www.thingiverse.com/thing:488678)
- Everything else is 100% Stock SeeMeCNC parts
Excessive Speeds:
I'm having problems with my prints suddenly accelerating to what appears to be well over 35mm/s after the first layer. It gets to the point where material will just clump onto the hotend. This also doesn't appear to be software related, because I have tried it on MatterControl (MatterSlice), Slic3r, KISSlicer, and Cura. All of them have strange issues where they suddenly speed up in inappropriate areas and to excessive amounts. Also, the extruder can never seem to keep up, so filament gets smeared, dragged, etc everywhere sometimes. Also this seems to be consistent with larger prints, or prints with tight/small circles.
Power Cutout on Heating:
Occasionally when I try to heatsoak my hotend while warming up my bed my printer will shut itself off (appears to be PSU or Fuse, since the Rambo board completely shuts off). I'm wondering if it may however be a firmware issue.
Also I should note that I did have a Rambo fry on me way back when I first build my rostock due to a faulty Terminal, I had the terminal and nearby capacitor replaced, but the PCB was fine (this was done by Ultimachine themselves). I am also using insulated quick disconnects for my Hotend connections, however, I never have cutouts if I solely heat the hotend.
E3Dv6 Mount Skewed?:
This is the biggest issue at the moment by far. It seems that my mounts for my E3Dv6 recently placed the hotend at a slight canted angle, causing high layer heights towards the Y motor (~0.28mm) and very low to even smashed/non-existent layers on the X side (~0.12-0.18mm, sometimes no extrusion). This is with a starting layer height of 0.25mm, so it is rather outside of the range of accuracy and to a point where it causes extreme problems in larger prints (including layer collision).
Now what I'm wondering is if anyone ran into something similar because they 3D printed their E3D mount, and if so what did they do to workaround it. Otherwise, I'm wondering what alternatives I have since I would like to continue to use the spacers I bought and the rostock adapter probably wont work with them due to their height.
That's my list of issues so far. Thanks again for any help anyone in the community can provide, and if anyone needs pictures or any other information, please let me know!
-DK
