Belts cracking/wearing?
Posted: Thu Mar 05, 2015 5:44 am
by add1ct3dd
So I've had my printer since November, but doing a visual inspection yesterday while fixing a couple of issues, I noticed all 3 belts have a lot of cracking over their most used areas - now this seems pretty poor considering it's only 4 months old!
Anyone else had the same?
Presumably I should contact SeeMeCNC to get some new ones sent out? They should last longer than 4 months surely? Not even been printing that much!
Re: Belts cracking/wearing?
Posted: Thu Mar 05, 2015 5:55 am
by teoman
Are you sure?
They do have an odd texture on them.
Hnmm. I should go inspect mine aswell.
Posted: Thu Mar 05, 2015 8:09 am
I've been running the same belts for 2 years without any noticeable degradation. Teoman is right that they have a crackled texture to them right out of the gate, but they are real industrial belts that I'm sure have conditioners in the rubber to keep them from oxidizing.
Posted: Thu Mar 05, 2015 10:10 am
by add1ct3dd
I'll see if I can get a picture of them, it's the first time I've noticed it and never seen it on my other printer!
Here's a pic:
[img]http://i.imgur.com/vPEKo5Vl.jpg[/img]
Sorry to worry you guys, it does indeed seem to be the texture, my bad for not inspecting it properly
One thing I did notice though, the belt is rubbing the edge of the V-slot slightly (you can see the deposits on the right hand side), is there a way to stop this at all?
Posted: Thu Mar 05, 2015 12:16 pm
by KAS
That's basically the alignment of the belt tensioner. Certain angles will cause the belt to track towards the outer edges of the bearing until it contacts something. It's a juggling game of proper tension while trying to keep the alignment of the screw going through the bearing parallel with the bearing at the bottom.
Posted: Thu Mar 05, 2015 1:45 pm
Your best bet is probably just to file the sharp edge off of that part of the extrusion. It's a tight tolerance for that belt, and KAS is right that it's nearly impossible to adjust your belt tension without causing the belt to cant slightly.
