Vapor Smooth PLA
Posted: Sun Mar 08, 2015 12:24 am
Re: Vapor Smooth PLA
Posted: Sun Mar 08, 2015 12:25 am
I knew THF was the right chemical to use, but I didn't know that I could buy it at the store. Cool!
Posted: Sun Mar 08, 2015 1:06 am
by teoman
What is thf and what can you buy it at the store?
Sorry, i watched the video but it is very noisy here, did not hear much.
Posted: Sun Mar 08, 2015 9:03 am
by Mac The Knife
They were using PVC pipe cleaner, a hardware, or plumbing supply store would have it.
http://www.mscdirect.com/product/detail ... 0=37035946
Posted: Sun Mar 08, 2015 10:40 am
PLEASE BE CAREFUL with this stuff. It is a mixture of acetone and methyl ethyl keytone (MEK) MEK is much more flammable and flashes with far less provocation than acetone and is carcinogenic (absorption through skin and breathing vapor). It is seriously nasty stuff so please do some research (google MEK and "PLA + MEK") before rushing into it.
Regards,
Michael Hackney Ph.D. Chemistry (adds credibility? and it's true)
Posted: Sun Mar 08, 2015 12:00 pm
by teoman
Fould a source for mek. 20 usd for5L.
Is it the mek component only or does acetone also play a role?
Posted: Sun Mar 08, 2015 12:27 pm
by DavidF
The MEK substitute found at local hardware stores works too.
Posted: Sun Mar 08, 2015 2:10 pm
by teoman
I am afraid our hardware stores are a lot different than yours.
And use a different vocabulary.
Posted: Sun Mar 08, 2015 3:04 pm
by KAS
Huh, PVC cleaner? I have this in the garage right now.
be right back... I hope
Posted: Sun Mar 08, 2015 3:27 pm
by KAS
I just have the purple stuff, not sure if it would fume that color or not.
Brushed it on and applied a little heat, the PLA turned gooey then turned rock hard when it evaporated and cooled.
I don't have a heat plate.
[img]http://i482.photobucket.com/albums/rr189/Onuxis/20150308_151430.jpg[/img]
[img]http://i482.photobucket.com/albums/rr189/Onuxis/20150308_151935.jpg[/img]
Posted: Sun Mar 08, 2015 3:30 pm
by teoman
Thank you for the pictures.
Posted: Sun Mar 08, 2015 3:36 pm
by KAS
Posted: Sun Mar 08, 2015 6:13 pm
by bubbasnow
mhackney wrote:PLEASE BE CAREFUL with this stuff. It is a mixture of acetone and methyl ethyl keytone (MEK) MEK is much more flammable and flashes with far less provocation than acetone and is carcinogenic (absorption through skin and breathing vapor). It is seriously nasty stuff so please do some research (google MEK and "PLA + MEK") before rushing into it.
Regards,
to the state of California, H20 is a carcinogenic...
Posted: Sun Mar 08, 2015 9:50 pm
by DanHall
The NIOSH PEL for acetone is 1000ppm and for MEK it is 200ppm. Doc Hackney is just looking out for all of you. How many of you have the equipment at home to measure airborne concentrations? I don't. In the garage with properly rated gloves, both garage doors open, an APR and goggles... I have used MEK for removing automotive paint but it is still not a recommendation. Also be careful with heat sources or any other source of ignition.
I'm not a chemist like Doc but I am a Chemical Engineer who has spent a significant portion of my career dealing with chemicals that will kill at much lower dosages than either MEK or acetone.
Posted: Mon Mar 09, 2015 12:00 am
by barry99705
MEK is some nasty crap. We can't use it in the military anymore. Used to be a great paint remover.
Posted: Mon Mar 09, 2015 8:19 am
Not only is it more flammable... PLA is made out of organic compounds, so anything that dissolves it will also dissolve you.
After reading a bit more on it, perhaps this chemical is a better candidate for cold vapor smoothing.
Posted: Thu Mar 12, 2015 12:24 am
by 626Pilot
I understand people have used heated acrylic cement vapor to smooth PLA. I think that's rubber cement, isn't it? The fumes are still something you'd expect to find in a lake on Saturn, but perhaps better than that pipe cleaner stuff.
Posted: Thu Mar 12, 2015 5:43 am
by teoman
What is the main ingredient in that?
Posted: Thu Mar 12, 2015 7:19 am
by Mac The Knife
Posted: Thu Mar 12, 2015 3:46 pm
Not something I would want to do indoors.
Posted: Sat Mar 14, 2015 1:34 am
by 626Pilot
Another thing you can do is coat your model with some of this stuff, which Taulmann found could make T-Glase almost completely transmissive to light (no layer-lines). The stuff works on PLA as well.
I would probably use it outdoors.
http://taulman3d.com/t-glase-optics.html
