Windows 32, 64 and Max. Linux to come soon.
Some new features for those support users! (gee, maybe I should check out what all the hoopla about support structures is all about!)
Changes from 2.16:
Arbitrary Z-gap is now allowed
Fixed a bug where the wipe and destring following support interface paths where at the wrong height when Z-Gap was used.
G-code summary at the end now includes per-extruder filament length (and volume) used.
Optimized object slicing with many small sub-meshes.
You can now add up to 5 layers of support interface on top of the raft.
Pressing delete anywhere in the model tab no longer deletes the model.
Fixed a bug where the animation slider would reset itself every second.
Fixed bug when Slice-and-Save is checked and we cancel the file selection.
Every-N-Layers now doesn't drag-value-change.
Added a squiggle-base to the prime pillar to help it adhere to the bed / raft.
