Water cooled hot end. Just the begining.
Posted: Sun Aug 12, 2012 9:06 pm
I am on my 2ND rebuild of my hot-end. The first melted down because the board got shorted and turned the head on full for who knows how long. Then the second happen last night after working on getting the h1 printing for the first time. I was just getting good extrusion speed set and then the head just melted off.
[img]http://i1151.photobucket.com/albums/o634/thewiredmechanic/th_IMG_0088.jpg[/img]So after some research I found this little head. http://blog.reprap.org/2012/07/water-co ... t-end.html
Well it was off to cad and some drawings. I was able to make a mock up out of foam.
[img]http://i1151.photobucket.com/albums/o634/thewiredmechanic/th_IMG_0091.jpg[/img]
And then I was able to cast the head.[img]http://i1151.photobucket.com/albums/o634/thewiredmechanic/th_IMG_0095.jpg[/img]
All I have left to do is clean it up, drill and tap the holes.[img]http://i1151.photobucket.com/albums/o634/thewiredmechanic/th_IMG_0102.jpg[/img]
I also liked the idea of using a through hole thermistor. The thermistor will be installed just like the resistors. This should prevent the head from getting out of control .
This is the part after a quick clean up.
[img]http://i1151.photobucket.com/albums/o634/thewiredmechanic/th_IMG_0106.jpg[/img]
