Printable recirculating linear bearings for carriages
Posted: Tue Mar 17, 2015 7:43 pm
by 626Pilot
[youtube]
http://www.youtube.com/watch?v=UTxivqmK4s0[/youtube]
[youtube]
http://www.youtube.com/watch?v=5XYYfqwidLk[/youtube]
Uses 3/16" delrin balls. The finished carriage with bearings and bolts is about one ounce. I have some delrin balls on order!
Re: Printable recirculating linear bearings for carriages
Posted: Tue Mar 17, 2015 7:45 pm
by Nylocke
I have those on the Mini Kossel I made for my school. Really cheap and its delivering good results. Seems like there aren't a lot of people using them, not sure why.
Posted: Tue Mar 17, 2015 7:55 pm
We printed 2 sets of these for mini kossels for my son and his friend. They work really well but they are a little noisy.
Posted: Tue Mar 17, 2015 8:13 pm
I printed the bearing when Johann first published the design the best part of a year ago, they do work surprisingly well, it's a cool print if nothing else. You want to make sure not to over pack the bearings, one too few doesn't hurt.
Posted: Tue Mar 17, 2015 8:21 pm
by mvansomeren
Very cool! Where can I get the stil files?
Posted: Tue Mar 17, 2015 10:56 pm
by Jimustanguitar
mvansomeren wrote:Very cool! Where can I get the stil files?
Just about anything that Johan does is on the Mini Kossel GitHub... I'd look there first.
Posted: Tue Mar 17, 2015 11:08 pm
by Nylocke
You would think, but it actually has its own repo:
https://github.com/jcrocholl/recirculating
I used these
http://www.thingiverse.com/thing:581271 for the carriages. The default design has them too close to the extrusions.
Posted: Tue Mar 17, 2015 11:09 pm
Posted: Wed Mar 18, 2015 7:01 am
Eagle, that is Johann's main git. If you click on his name you will see all of the git repositories he created.
Posted: Wed Mar 18, 2015 7:15 am
mhackney wrote:Eagle, that is Johann's main git. If you click on his name you will see all of the git repositories he created.
Hey Michael, it worked! Thanks for the info and I learn something everyday thanks to users like you!
Posted: Wed Mar 18, 2015 7:33 am
I use this recirculating carriage as a perfect example of designing support into the model. There is no way any automated support generation in a slicer could generate support that would allow printing this model so it works without major trimming. Johann designed in a "zipper" support that literally just zips off leaving a clean model. It is brilliant and something that I use in my designs now. This type of support can be manually added to any STL file with a CAD or STL editing app too.
Posted: Wed Mar 18, 2015 12:02 pm
mhackney wrote:I use this recirculating carriage as a perfect example of designing support into the model. There is no way any automated support generation in a slicer could generate support that would allow printing this model so it works without major trimming. Johann designed in a "zipper" support that literally just zips off leaving a clean model. It is brilliant and something that I use in my designs now. This type of support can be manually added to any STL file with a CAD or STL editing app too.
The early model didn't have designed support, it was added, you could print it in Kiss which is what I did by setting the maximum support height to be slightly higher than the bottom of the lip. I'm in two minds on manual support, when it's good it tends to be the best option, I occasionally see poorly designed manual support which is just annoying because it's often virtually impossible to remove.
Posted: Wed Mar 18, 2015 3:15 pm
Agreed and the design issue goes to models too. There is a lot of less than optimal crap out there. Good designers do good designs and think through the support issues.
