Stops extruding - Wrong temperature?
Posted: Mon Mar 23, 2015 9:44 am
The problem:
The printer stops extruding suddenly. At first mid print and now all the time.
I have a Rostock Max V2 printer and it started to do bad prints suddenly a few weeks ago and before that i never had a problem with it with 2 months of regular use.
Layers stopped sticking together and after a while it stopped extruding completely. I suspect its the temperature that drops because when using a IR thermometer pointed at the nozzle I get a reading of about 50c lower than indicated.
It clogs the nozzle pretty quick and only clumps of filament get out every few layers. I have cleaned out the nozzle 3 times and after the first time i managed to get about 10 hours through a 15 hour print before it clogged up again and the extruder started digging through the filament. When i cleaned it again it started clogging after a few seconds.
Everything is stock on this printer.
When i try to push filament through by hand i can't and it feels like its not hot enough even though it says 230
What i have measured:
In room temperature i get 21c both from the IR thermometer and from the lcd display.
The same happens at 100c so when I point the IR thermometer towards the hotend it says 100c.
When i heat up the hotend to 200c it says 200c on the lcd but when using the IR thermometer i can't get it over 170c at all and when i put it up to 230 i get something like 180 at most with the IR temp.
Did a thermistor break down on me or is the problem something else altogether?
I dont know even know if the hotend is supposed to reath the same temperature on the outside as it does on the inside so maybe measuring with the IR thermometer is useless?
I'm really tearing my hair off here!
http://imgur.com/a/jvi8S
