Print Glass and all pushed off printer
Posted: Mon Mar 23, 2015 4:35 pm
by enchantedsord
Hello everyone!
Well I have had my machine up and running since december and when printing small parts for the most part I have no issues and it looks good, but I have recently tried to print a part that about 8 inches square and up to about 4 inches high or so and somewhere between 12-24 hours into the 35 hour print it seems to catch somewhere and it has slid the entire glass piece and all off the printer. I have tried it in mattercontrol and cura and cura was able to get the furthest in the print ruffly 24 hours but both times the glass print and all was pushed off. Kinda scarey.
Luckily no damage but I can't seem to figure out the issue. I'm using the .35 nozzle and it seems like once it gets higher the nozzle is dragging and I think what is happening is it finally catches and gets stuck then pushes the part.
Any idea how I might go about correcting this? I have added some additional z hop but it seems like it's happening when it moves within the same layer and there is no z hop. Could it be over extruding, filament temp?
Anyway maybe I need to try some more calibration. What do you generally recommend besides the paper under the tip thing.
When I print smaller parts it doesn't seem to be an issue but I do definitely see drag over parts of the same layer when it crosses.
thanks
Larry
Re: Print Glass and all pushed off printer
Posted: Mon Mar 23, 2015 6:22 pm
by Mac The Knife
The diagonal of an 8 inch square, by my calculator, is 287.36 mm. That's a little ambitious, considering the print area is advertised at 280mm and that is pretty optimistic in itself. What speed are you printing at?
Posted: Mon Mar 23, 2015 7:33 pm
by enchantedsord
I have it printing pretty slow and it printed out 1inch then it kicked it and plate off. I have it set to the following...
30 mm/s infill
30 mm/s inside perimeters
30 mm/s outside Perimeter
40 mm/s Support mat (no supports in this print though)
60 mm/s bridges (no bridges)
150mm/s non print moves
12mm/s First Layer
If it matters any this is what I was printing. I tried both trays and had the same issues with both at different heights.
http://www.thingiverse.com/thing:176679
Posted: Mon Mar 23, 2015 8:05 pm
Most likely you are over extruding, eventually the build up of plastic is enough to catch the nozzle.
The nozzle should drag through the existing plastic.
print a single wall test piece and measure your extrusion width this is a piece I wrote on it a while back http://forum.seemecnc.com/viewtopic.php?f=54&t=1163
Posted: Mon Mar 23, 2015 9:41 pm
by bot
I'm with Mac the knife on this one. Given the information you provided, I can only assume that you have very poor, if any, adhesion on the areas that extend way beyond the build volume of the printer. They will curl up, your nozzle will hit them and apparently move the glass. Do you have the glass clamped down? I've never had that happen personally.
Posted: Tue Mar 24, 2015 1:43 am
by enchantedsord
Yeah it's clamped down with 6 clips. I checked the adhesion but it was really good and took a bit to get the print off . I'm thinking over extrusion also. I'll try his print and sees what I get.
Posted: Tue Mar 31, 2015 7:01 am
by hugepanic
check the Z-lift!
I had issues with it on my larger prints. No i have a Z-lift of about 1.3 or 1.5mm and no problems.
see http://forum.seemecnc.com/viewtopic.php?f=62&t=7509
If you have no z-lift, the nozzle might catch a structure when moving fast. This is especially true wenn you get cracks in your parts. At one point the part cracks and the height of the residual part is higher than the nozzle. So when the printer moves, the nozzle will rip the part in half or from the plate.
Posted: Fri Apr 03, 2015 7:34 pm
by TFMike
This had to be done with ABS right? Have you thought about trying a different material?
Posted: Fri Apr 03, 2015 10:49 pm
Did you calibrate your cold extruder according to the manual?
Posted: Fri Apr 03, 2015 11:31 pm
by 3D-Print
This happened to me although I didn't catch hard enough to drive the glass off the printer. I found my X-axis belt adjuster slipped (didn't tighten it "Dan tight" as my kids call it) and the X-axis belt had too much slack. After 3 failed prints I watched until it happened. When the X-axis was at it lowest point and the print head was near the Z-axis the fail occurred when the X-axis began to raise and the Z-axis drop. When the print head changed directions the slack in the X-axis belt resulted in a slight delay in movement that in combination of the Z-axis downward movement resulted in the print head hitting the print so hard that the head jumped 3-4 inches away from the print line and gouged the printed surface.
I readjusted the tension on my belts and the problem resolved. I've printed some belt tensioners to keep them stable and tight. Installing them this weekend.
Dan
Posted: Sat Apr 04, 2015 12:07 am
3D-Print wrote:This happened to me although I didn't catch hard enough to drive the glass off the printer. I found my X-axis belt adjuster slipped (didn't tighten it "Dan tight" as my kids call it) and the X-axis belt had too much slack. After 3 failed prints I watched until it happened. When the X-axis was at it lowest point and the print head was near the Z-axis the fail occurred when the X-axis began to raise and the Z-axis drop. When the print head changed directions the slack in the X-axis belt resulted in a slight delay in movement that in combination of the Z-axis downward movement resulted in the print head hitting the print so hard that the head jumped 3-4 inches away from the print line and gouged the printed surface.
Dan
Dan, which belt tensioners did you decide to use?
Posted: Sat Apr 04, 2015 1:05 am
by enchantedsord
I would love to find out also.
Posted: Sat Apr 04, 2015 6:10 am
by 3D-Print
Here is a link to the thread and files which "KAS" posted (http://forum.seemecnc.com/viewtopic.php ... 5&start=96)
Hope it helps!!
Dan
Posted: Sat Apr 04, 2015 6:18 am
3D-Print wrote:Here is a link to the thread and files which "KAS" posted (http://forum.seemecnc.com/viewtopic.php ... 5&start=96)
Hope it helps!!
Dan
Thanks Dan, those look like they are strong and should work fine!
Posted: Sat Apr 04, 2015 6:21 am
by 3D-Print
As well, I have wondered if there is a more accurate way to adjust the tension. I my "build thread" we have talked about a few ideas to do this but not sure how precise this really needs to be though (http://forum.seemecnc.com/viewtopic.php ... &start=104).
I can envision you could have trouble with loose belts if you are trying to printing a 0.2 mm thick layer whereas if your layer was 0.3 mm or 0.4 mm you would have no problems with drag or catching the hotend on the print. Moving the print glass or as with my problem is the extreme example of a loose belt.
Posted: Sat Apr 04, 2015 6:23 am
by 3D-Print
I agree, I printed them with a 90% infill. The main concern I had was with the strength of the tension "tabs." I printed one of each then "cranked on them" with a pair of pliers and they are quite strong.
