Fixing the little problems in the print - How?
Posted: Tue Mar 24, 2015 7:02 pm
I just finished building a Rostock Max v2. It's my first experience with a 3d printer and I'm pretty darn happy and amazed that everything actually works. However, I have no idea how to tweak things to fix the little problems with the prints. Here is a picture of a fairly detailed print I just finished:
[img]http://i.imgur.com/w5YB2qZ.jpg[/img]
As you can see it's almost perfect. There are a few defects however, and after much googling and searching the forums I've only been able to find the fix to one of them. I'm hearing pops when I print and I get these little divots. I found out that my filament was shipped with moisture problems (from Amazon). So I know how to fix that issue. The rest are puzzling me.
Under his leg cuffs and his arm is pretty ratty. I believe this is a bridging problem? I'm not quite sure how to fix this. I believe they are sagging which I think means I need to have the bridges print faster - is this correct?
The other problem I'm getting is these random little knobs where plastic is where it shouldn't be. I have no idea what causes this or what to look for to fix it.
The final problem is a line that appeared on the side of his chest. There is also a burn mark in there. What could have caused that?
I know I'm pretty fortunate to get such good prints right away, but now I'm trying to learn how to solve the mysteries of drilling down and getting perfect prints.
