Cheap MDF Enclosure with Plexiglass Door
Posted: Sun Mar 29, 2015 6:52 pm
Hi All,
First post here, but have been reading for a few weeks. Thanks to a lot of you, I am able to build my 3d printing knowledge with my MAX V2. I keep my V2 in my bedroom, as I have little ones that would love to get there hand on it anywhere else in the house. This is right next to the window which was affecting prints just through the ambient temperature of the nearby area. I already spent a ton on upgrades, so wanted to make a budget enclosure that would do a decent job.
[img]http://i.imgur.com/o24eAjX.jpg[/img]
This enclosure is made of mostly by a 4'x8' sheet of medium density fiberboard (MDF). The plexiglass on the front is from Lowe's and is a little over 5mm thick. (0.220"). I used corner braces to secure everything in place and hardware I had around the house. I have it lit with a 1400 lumen undercounter LED light which is probably overkill. This thing lights my whole room up from inside the enclosure. It is much needed though, the above picture is with the bedroom light turned on, it is very dim and was previously very hard to see the print.
All in all, the sheet of MDF cost $30 for the 4'x8', the plexiglass was $60 for the 5mm thick (I spent a little more here because one of the goals was to soundproof as much as possible). The hardware (corner brackets, hinges, screws, washers) was probably $15 tops.
I figured I would share this for anyone looking for a cheap, yet stable enclosure for their printer.
Thanks
Thanks
