Tower offsets not working at all
Posted: Thu Apr 02, 2015 4:17 pm
Hi everyone,
My X tower is about 3mm too low (nozzle hitting the glass) and the screw is tightened as far as it can go. I've tried to change the X tower offset in the EEPROM as well as in the Configuration.h file and there is zero effect in the positive & negative directions.
Has anyone else had this problem and found a fix?
Thank you!
Aaron
Thank you!
Aaron
