Printer Finally up and running
Posted: Tue Apr 14, 2015 4:25 am
by taav
Finally printed out my first test cube.
Its far from being perfect, I have not done any fine tuning yet on the extruder, and i think i detected some slight slanting as well, accepting any and all tips for fine tuning, so I can make my next cube a perfect one!
Thanks in advance
[img]
http://i131.photobucket.com/albums/p283 ... mjoojh.jpg[/img]
Does this look square enough?
[img]
http://i131.photobucket.com/albums/p283 ... 2wme40.jpg[/img]
Another angle.
[img]
http://s131.photobucket.com/user/photof ... sort=3&o=0[/img]
Re: Printer Finally up and running
Posted: Tue Apr 14, 2015 2:12 pm
You need to calibrate the cold extruder and do the complete calibration of the printer as indicated in the manual.
Good print for not being calibrated!
Posted: Wed May 06, 2015 9:03 am
by taav
Hey thanks.
So by the cold extruder calibration you mean the triffid hunter calibration?
http://reprap.org/wiki/Triffid_Hunter%2 ... tion_Guide
^this one?
If so whats the easiest way to figure out this information?
Know your stepper motors' full steps per revolution value. steps = 360 / angle, so 1.8° = 200 steps, 0.9° = 400 steps, etc.
Know your stepper drivers' microsteps setting. Most Pololus are set to 16x. GEN3 driver 2.3 is fixed to 2 (half step). Some boards have 32x.
Know the number of teeth on your pulleys. Standard printed pulleys have 8 teeth. Most machined pulleys have 10 or 12 teeth since 8 tooth is technically too small for T5 belt
Know your belt pitch! XL and T5 belts /look/ the same, but the difference is important!
Know the number of teeth on your extruder gears, or at least the gear ratio.
Posted: Wed May 06, 2015 3:23 pm
I like to follow the calibration procedures set forth in the assembly manual , Triffid Hunter is okay also but I wish everyone would use the manual first and other methods if necessary which they should not be.
Posted: Thu May 07, 2015 6:46 am
by crocky
What he said, follow the manual steps... You don't need any other settings until you have got it properly configured.
Posted: Thu May 07, 2015 6:51 am
by Tincho85
