Controlling the Extruder Fan
Posted: Sat Apr 25, 2015 1:30 pm
				I have questions about controlling the extruder fan for my Orion printer. But first, here are my issues:
1) When I am warming up the extruder to a target temperature, the extruder fan kicks on. This seems counter productive as the fan is cooling as the extruder as it is trying to warm up. I noticed it takes a while for the extruder to warm up. Also, if my target temperature is high, say over 230 degrees, the extruder will simply not be able to get up to temperature and peaks out at about 225 degrees. I found if I put my finger on the extruder fan to stop the fan while the extruder is warming I can cut the warm-up time by half and easily reach my target temperatures. Once the target temperatures are reached, I release my finger and let the extruder fan come back on.
2) I noticed that while printing, my real extruder temperatures are always 10 to 15 degrees lower than my target temperatures. It seems again, the extruder fan is cooling the extruder too much. So again, during the printing, I carefully put my finger on the extruder fan to stop it until I can see on the LCD display that the target temperature is has been reached. As soon as I release my finger and the fan kicks in, the extruder temperatures again drop.
So my question, do you recommend any way to automate the extruder fan on/off or speed to better match the extruder target temperatures with the extruder real temperatures?
Thanks, Mo
Thanks, Mo
