Need Help Auto Tuning Heated Bed
Posted: Sun Apr 26, 2015 3:57 am
Good Morning
My Rostock Max v2 was purchased used, even so I am learning a lot. I decided to hook up a 24 volt power supply to power my heated bed. I am using the out put from the control board (originally to the bed) from Rambo to control a solid state relay. To test this I used the lcd control panel turn the bed on and off. So far so good. The problem I am having is auto tuning the bed. When issuing the command to auto tune the hot end starts to warm up. I am issuing the following command "M303 E2 S90" I assume E2 because that is where the power is coming from to switch the relay (Heat Bed 2 as the board indicates). The instruction manual describes the procedure to auto tune the hot end (the command is "M303 S200", as I understand when the "E" is left out extruder 0 is assumed) I have tried googling for help but no luck. Could it be that I need to change something in the eeprom with Matter Control. I have never tried to auto tune the heat bed before but was successful at auto tuning the hot end. Can someone here please help
Thanks again for your help.
