Dead Smoothieboard
Posted: Mon Apr 27, 2015 6:44 pm
by KAS
So it appears I have a dead smoothieboard. Been fighting with it for a week and cant get anything beside the 3.3v to light up.
I'm only using USB, but apparently I should be seeing 1,2,3, and 4 light up on the LEDs.
good times...
Re: Dead Smoothieboard
Posted: Mon Apr 27, 2015 8:18 pm
by JFettig
You should e-mail the place you bought it from so you can get a replacement.
Posted: Mon Apr 27, 2015 8:43 pm
by KAS
I did, just waiting for a response. Tried a few things they suggested on the IRC with no luck.
You get yours up and running yet?
Posted: Mon Apr 27, 2015 10:48 pm
by JFettig
I'm printing parts to build the printer it'll go in - might use machinekit however.
Posted: Mon Apr 27, 2015 11:34 pm
by forrie
On power up (plug in usb) you should see 1,2,3,4 light up green one at a time then fast flashing. 3.3v should light up orange/red as well.
Posted: Tue Apr 28, 2015 12:21 am
by 626Pilot
You can try soldering in a 5V voltage regulator according to the documentation. That will let it run off PSU power instead of USB. It might work. I don't know how long I would trust a board that requires it.
Another thing - you have to connect power at 3 separate locations. If you only connect one or two, it won't work. However, this would not stop the board from booting - only from activating the FETs that send the current.
Posted: Tue Apr 28, 2015 6:43 am
by KAS
It's definitely dead. I get the 3.3v led only when using USB. None of my computers recognizes that anything is plugged in via usb.
Still no reply from uberclock.
Posted: Tue Apr 28, 2015 4:45 pm
by KAS
Update: He is sending a replacement.
Posted: Wed May 06, 2015 5:53 pm
by KAS
I promise if I wasn't so invested in the smoothieboard to work, Id tell everyone to avoid them like a plague.
Between them not shipping the GLCD with no communication, then receiving a dead board.. The replacement came today with a capacitor broken off and the 4x power header replaced with a 2x. But it has a QC Pass sticker, so I guess it's good to go.
Hopefully no other issues or surprises.
Posted: Wed May 06, 2015 8:22 pm
by KAS
After an hour of trying to figure out why the LCD wouldn't turn on, noticed the GLCD shield had a lifted smd capacitor. I'm glad I at least have another set to compare...
Posted: Wed May 06, 2015 9:50 pm
by bot
I've heard other stories of problems like this with smoothieboards, which is why I scared myself away from the group buy: such massive increased productivity leads to bad QC. Even though Rambos are less sophisticated, they can be had from a reliable source.
Posted: Thu May 07, 2015 8:29 am
by Mac The Knife
I ordered an Azteeg X5 mini for my Heavy Metal build,,, I'll be curious to see how it looks when it shows up.
Posted: Thu May 07, 2015 11:39 am
by bvandiepenbos
That's disappointing. Guess I better check out the board I have. I had not really checked it out as I to am waiting for the glcd I ordered with board.
Posted: Thu Jun 18, 2015 9:47 pm
by mlapaglia
I'm on my third board.. First one had a dead stepper, second one would randomly turn off after a few minutes of printing, and now the third I am still trying to get working..
Posted: Fri Jun 19, 2015 12:40 am
by 626Pilot
mlapaglia wrote:I'm on my third board.. First one had a dead stepper, second one would randomly turn off after a few minutes of printing, and now the third I am still trying to get working..
I went through two Azteeg X5s in six months (maybe less?) when I was first getting into Smoothie development. The first one lost its heated bed FET, which is a tiny cheesy little surface-mount component. The second started stuttering at random times. If I homed it, it would slam into the endstops and grind the belts because it didn't
care about the endstops. If it got through homing, it would stutter and head-crash sooner or later.
Got a Smoothieboard about six months ago... been beating the hell out of it, developing my Smoothie fork... it's still kicking. I hope #3 works better for you.
Posted: Fri Jun 19, 2015 1:54 am
by bot
I hope so too, I just got one...
