Calibbration Macros Quit Working properly in Matter contro
Posted: Fri May 01, 2015 4:46 am
by Pyropainter
Well here I am again, I hope someone here can help. While calibrating the XYZ towers something maybe Matter Control has started acting up or this maybe related to another problem I am having. I will describe later. While recalibrating the machine (I have done this before with no problem). After pressing the XY or Z macro button and waiting for printer to stop then pressing the Bed Center macro button the printer moves to the XY or Z destination that it was at previously. Example pressing the Z macro button, printer moves to Z tower after motion has stopped I press the Bed Center macro button the printer heads towards the Z tower macro destination. The Home All Macro will clear this error. The Home Towers button on the LCD seems to clear this as well.
Another problem I was having prior to this is not being able to auto calibrate the heat bed or send temperature adjustments thru g code. I am still able to turn on and make adjustments with the LCD. However, after the heat bed issues showed up the Matter Control macro buttons were working as expected. I have been able to auto calibrate the heat bed as well as the hot end.
Any thoughts on either problem are appreciated. To me somehow they are related. One though I have is re installing the Repetier Firmware. I have never done this before as I have purchased this printer used. The thing worked when I purchased it, maybe it is just me. Oh well, I do realize it is all part of the learning experience (for me that is the fum part).
Thank you.
Pyropainter
Re: Calibbration Macros Quit Working properly in Matter cont
Posted: Sun May 03, 2015 9:48 pm
by Java
I've experienced the exact same issue with the macros
Posted: Fri May 08, 2015 1:33 am
by Pyropainter
Java, sorry to hear that you have or have had the same issues with Matter Control as I have had. I was just about to try something that would have led me down the wrong path to finding a solution. Instead, I set up the same macros in Pronterface and found them to work correctly. To me this meant something was wrong with Matter Control. After uninstalling and reinstalling Matter Control I found that my macros were still there. Obviously I was doing something wrong. Not being a computer guru I emailed Matter Control technical support. Ryan emailed back with the information needed for a clean install. I again uninstalled Matter control then followed his directions. This is what he had to say.
"While I can't exactly determine what the issue that caused the macros to stop working, I think we can get your macros working again by clearing the application's data. The application data is stored in a folder separate from the program files, which is why uninstalling and reinstalling the program did not make a difference and all your settings were still there afterward. Follow the instructions for your operating system:
Windows: Delete the MatterControl folder in C:/Users/%Username%/AppData/Local/ (AppData may be hidden)
Mac OS X and Linux: Delete the MatterControl folder at ~/.local/share/ (.local may be hidden)"
A big thank you to Ryan.
The AppData file was hidden and I had to change to change my computer settings to allow it to be shown. Also the macro buttons had to be reprogrammed as described in the Rostock Max Manual. Now I did delete the AppData file before reinstalling. I did loose any work that I had been done previously. You may be ale to avoid this if you are more careful and experienced than I. I did not have mush to lose. But now things are working properly and that is what I was after.
I hope that this information is found to be useful to you or anyone else with the same problem.
Posted: Mon May 11, 2015 10:42 pm
by Java
Thanks for posting your solution!
