Imperfections
Posted: Mon May 04, 2015 3:49 pm
Greetings!
So, I am assembling my new Rostock Max v2 kit, and got to the assembly of the cheapskates. They went together fine, but when I moved onto adjustment, I had a bit of trouble. Two of them were adjusted fine, but one is giving me trouble. It sounds like the "clicking" of an improperly adjusted roller, but it's actually catching. I examined the "tires" on the bearing and there is an imperfection in the surface that is in contact with the tower. The cheapskate is adjusted perfectly finally (no torquing on any of the axis, falls at the same speed as the others, etc.) but it's still making the clicking noise because of the imperfection. I tried to clean it up, but the noise is still there. Should I get a new "tire" for the bearing, or is it not going to affect my printing?
--cyber.shifter--
--cyber.shifter--
