Help - my first drawing-Sketup-Slic-Mach3
Posted: Fri Aug 31, 2012 7:37 am
by charles
I need help. I did the drawing in sketup, converted to G code by slic, and I load the Gcode MACH3. Do not adjust extrunder on the table. (G92 E0 reset extrunsion distance).
[youtube]http://www.youtube.com/watch?v=IqIjI_FBUvo[/youtube]
Re: Help - my first drawing-Sketup-Slic-Mach3
Posted: Fri Aug 31, 2012 8:25 am
by charles
I need help setting up.
Posted: Fri Aug 31, 2012 9:37 am
by johnoly99
In Slicer, under the printer tab, you need to choose Gcode flavor of Mach3/EMC It is exporting E codes for your extruder axis, and Mach uses A as the axis letter. Changing the gcode flavor will fix that problem.
Posted: Fri Aug 31, 2012 10:38 am
by charles
Thank you.
the correct setting:
[youtube]http://www.youtube.com/watch?v=OxFf4FFTHKM[/youtube]
Posted: Fri Aug 31, 2012 11:11 am
by johnoly99
Anytime! Glad we could help
