Change slicers
Posted: Thu May 07, 2015 8:51 pm
by fuhao1995323
Hello all,
Can anyone tell us how to change the slicer?
And what else calibration of printer we need to redo?
Thank you very much!
Re: Change slicers
Posted: Fri May 08, 2015 12:23 am
by Dale Eason
If you are using MatterControl then click on the "configuration" heading. Then look down the screen as find the "slicer engine" selection box. I don't think there is a need to change calibration setting. However each slicer has a slightly different set of parameters and options. The most important ones for all slicers are filament properties, bed size, nozzle size, temperature, layer height, infill, support, and speed settings. Each have some version of those and if you have known good values for one slicer try using them to start with.
Dale
