Rostock Max V2, stepper motors won't move trying to home.
Posted: Sun May 10, 2015 9:42 pm
by SecretObsession
I finished assembling a Rostock Max v2 and ran into an issue before I started the calibration section of the assembly guide. I'm unable to home the towers. I've tried to "home towers" from the LCD, which just causes the LCD to freeze for about 20-30 seconds, then beeps. The LCD has a message at the bottom which says Failed. Trying to home with MatterControl (controls) also yields no results. (I press the home all button, and it doesn't do anything.) I've tried to pass G28 gcode, but nothing happens.
I've searched the forums and I haven't found anything that had any solution posted with it. There are a few cases that seem similar, but their printers were working at one point.
I'm not sure if it's a configuration problem, I'm not sure what wiring I should be checking since the steppers don't require any assembly. (I'm under the impression that the towers should at least move, even if it's not in the preferred direction.)
I've cleared the eeprom using the example clear_eeprom program in the Audruino IDE.
Compiled and reflashed the Repetier firmware.
Checked End stop functionality.
I'm stuck, any suggestions?
Re: Rostock Max V2, stepper motors won't move trying to home
Posted: Sun May 10, 2015 9:50 pm
by Dale Eason
Have you run the end stop test as described in the manual to make sure you have them wired correctly? Sounds to me like they may be connected in reverse so that the board thinks they are already pressed.
Dale
Posted: Sun May 10, 2015 10:39 pm
by SecretObsession
Hi Dale, I reran the end stop test and they seem to be functioning correctly...
Without any end stops pressed.
->M119
<-ok 0
<-x_max:L y_max:L z_max:L
X pressed
->M119
<-ok 0
<-x_max:H y_max:L z_max:L
Y pressed.
->M119
<-ok 0
<-x_max:L y_max:H z_max:L
Z pressed
<-ok 0
<-x_max:L y_max:L z_max:H
->M105
Posted: Sun May 10, 2015 11:25 pm
by Dale Eason
Well that looks like the end stops are connected correctly. So now I'm past my level of expertise. Sorry.
Dale
Posted: Sun May 10, 2015 11:53 pm
by Earthbound
Can you adjust Z height from the control panel?
Are the motors free or locked?
Posted: Sun May 10, 2015 11:59 pm
by SecretObsession
Earthbound wrote:Can you adjust Z height from the control panel?
It doesn't physically do anything when I click to raise or lower. (I see the commands being sent, and printer responds with "ok 0")
Earthbound wrote: Are the motors free or locked?
They are free.
Posted: Mon May 11, 2015 12:53 am
by Earthbound
Check fuse F2. It feeds the motor drivers.
Posted: Mon May 11, 2015 1:17 am
by SecretObsession
The F2 fuse looks ok. https://i.imgur.com/2OpBq4H.jpg
(I recently swapped the fuse to make sure.)
Posted: Mon May 11, 2015 6:39 am
by KAS
can you take a picture of the Rambo?
Posted: Mon May 11, 2015 1:41 pm
by SecretObsession
KAS wrote:can you take a picture of the Rambo?
Here are few pictures of the rambo, if you need any more or of anything specific, let me know and I'll take more.
http://imgur.com/ATz9eWE
http://imgur.com/bTygePT
http://imgur.com/b7cDYVX
http://imgur.com/iRfoQ1P
http://imgur.com/Si8WNdC
Thanks.
Posted: Mon May 11, 2015 2:12 pm
by KAS
Looks like your stepper connections are reversed. Pin one ( little triangle on the connector) should be on the right of each socket on the Rambo.
Page 194 on the manual is sorta confusing because the different types of steppers the kit can ship with.
Although I would of expected them to still work in reverse, or jerk a little.
Here is how they look on mine.
Posted: Mon May 11, 2015 3:59 pm
by SecretObsession
KAS wrote:Looks like your stepper connections are reversed. Pin one ( little triangle on the connector) should be on the right of each socket on the Rambo.
I flipped the connectors around. Still no joy. I had an extra Rambo board laying around (since I initially thought that was the issue.) and swapped, still no joy. I just don't understand why all 3 are not working, it's surely a symptom within itself.
I think I need to rule out firmware since the problem persists between boards. (It can still be wiring or maybe power, but since all 3 are not working, I'm thinking it's firmware.) I built the firmware from https://github.com/seemecnc/Repetier-091-ROSTOCKMAX using what is currently in master. (Last change in February 16 2015.) Is anyone else running this build?
Posted: Mon May 11, 2015 4:36 pm
by Earthbound
I think it makes sense to start at the basics. Do you have a multimeter of some kind? Verify voltage on each pair of terminals where 12v lands on the RAMBo.
Posted: Mon May 11, 2015 9:21 pm
by SecretObsession
Earthbound wrote:I think it makes sense to start at the basics. Do you have a multimeter of some kind? Verify voltage on each pair of terminals where 12v lands on the RAMBo.
I pulled out my multimeter and checked the pairs. The 3 pairs are each reading 12.01v. (Just as a precation, I had some weird twisting when I bundled the wires, and it left much of the wire exposed. I cleaned them up and got it to where there isn't much bare wire exposed anymore. Retested, no change.)
Posted: Tue May 12, 2015 6:59 pm
by SecretObsession
Thanks everyone! The problem is now resolved. It was correctly identified earlier in the thread by Earthbound. (Reiterated by SeeMeCNC support. Thanks JJ!) The F2 fuse was actually blown. This is the first time I've worked with these fuses and I was just visually inspecting them, which was pretty worthless. (and dumb.) I took the multimeter to it, and sure enough the fuse was dead.
The issue was that the fan had a stray wire making contact with the other soldering point, which was blowing the fuse. I removed the solder and wiring and redid it. Tested for a short and wasn't hearing it anymore. Replaced the F2 fuse, and ran "Home Towers." Success!
Thanks again for the support!
Posted: Fri May 15, 2015 1:58 pm
SecretObsession wrote:Thanks everyone! The problem is now resolved. It was correctly identified earlier in the thread by Earthbound. (Reiterated by SeeMeCNC support. Thanks JJ!) The F2 fuse was actually blown. This is the first time I've worked with these fuses and I was just visually inspecting them, which was pretty worthless. (and dumb.) I took the multimeter to it, and sure enough the fuse was dead.
Glad that you found the problem!
Happy Printing!
